Batteries
Revision as of 11:31, 23 September 2025 by Davefiddes (talk | contribs) (Fix formatting of cell voltage table image and converrt broken youtube embed to a plain link link)
Wiki Category
Category:Battery
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
  • Overcharging
Li-ion pouch cells
Cell voltages / Type
OEM modules
Manufacturer Model Capacity (kWh) Weight (kg) w (mm) d (mm) h (mm) Gravity (kg/kWh) Volume (L/kWh) Voltage (V) Current (cont A) Current (peak A) Cell arrangement Cell type Chemistry OEM numbers
Tesla Model S 85kWh 5.3 26 690 315 80 4.9 3.3 22.8 500 750 6s74p 18650 Li-ion
Tesla Model S 100kWh 6.4 28 680 315 80 4.4 2.7 22.8 870 6s86p 18650 Li-ion
Tesla Model 3 LR (inner) 19.2 98.9 1854 292 90 5.2 2.5 91.1 971 25s46p 2170 Li-ion
Tesla Model 3 LR (outer) 17.7 86.6 1715 292 90 4.9 2.5 83.9 971 23s46p 2170 Li-ion
Tesla Model 3 SR (inner) 13.0 58.9 1385 326 90 3.7 91.1 603 24s31p 2170 Li-ion
Tesla Model 3 SR (outer) 12.0 58.9 1380 344 90 3.8 83.9 603 24s31p 2170 Li-ion
Tesla Model 3 LFP (inner) 13.38 86 1860 323 81 6.4 83 161 23s Prismatic LiFePo4
Tesla Model 3 LFP (outer) 15.07 93.48 1948 323 81 6.2 93.5 161 25s Prismatic LiFePo4
Calb 4s3p 2.19 12 355 151 108 5.5 2.6 14.6 900 4s3p Pouch Li-ion
Calb 6s2p 2.19 12 355 151 108 5.5 2.6 22.2 600 6s2p Pouch Li-ion
Chevrolet Volt 2012 4 38 470 180 280 9.5 5.9 88.8 676 24s3p Pouch Li-ion
BMW i3 60Ah 2 13 410 310 150 6.5 9.5 28.8 210 350 8s2p Prismatic Li-ion
BMW i3 94Ah 4.15 28 410 310 150 6.7 4.6 45.6 409 12s Prismatic Li-ion 61 27 8 647 912
BMW i3 120Ah 5.3 28 410 310 150 5.3 3.6 45.6 360 12s Prismatic Li-ion 61 21 8 851 706
BMW PHEV 34Ah 2.0 13.05 368 178 102 6.525 3.34 59.0 16s Prismatic NCM 811
BMW PHEV 68Ah 2.0 13.05 368 178 102 6.525 3.34 29.5 8s Prismatic NCM 811
Jaguar iPace 2.5 12 340 155 112 4.8 2.4 10.8 720 1200 3s4p Pouch Li-ion
LG 3s4p 2.6 12.8 357 151 110 4.9 2.3 11 3s4p Pouch Li-ion
MG ZS EV (2021) 64.6Ah 2.74 13.6 390 150 115 4.969 2.338 21.9 125 375 6s2p Prismatic NMC
Nissan Leaf 24kWh 0.5 3.65 300 222 34 7.3 4.5 7.2 130 228 2s2p Pouch Li-ion LMO
Nissan Leaf 30kWh 1.25 300 222 34 3.6 14.4 4s2p Pouch Li-ion
Nissan Leaf 40kWh 1.6 8.7 300 222 68 5.4 2.8 14.4 314 4s2p Pouch Li-ion NMC
Nissan Leaf 62kWh 2.58 14.4 4s3p Li-ion
Porsche Taycan 2.77 12.7 390 155 115 4.9 2.3 21.9 360 600 6s2p Pouch Li-ion
PSA/Opel Peugeot E-208, Corsa E (Forum post) 2.73 12.7 390 150 115 4.6 2.5 21.9 6s2p / 6s1p Prismatic Li-ion
Volvo V60 1.3 11 120 310 185 160 10S Poucch Li-ion
VW Passet GTE 2.48 23.4 (with cooler plate)
10.8kg single
410 (C/P)
355 (S)
235 (C/P)
150 (S)
150 (C/P)
108 (S)
VW Golf GTE 1.086 9.8 355 152 110 9.02 5.5 44 12s Prismatic Li-ion 5QE 915 591 H
VW Touareg 14,1 kWh 1.76 12.3 385 150 108 7.0 3.5 45.25 13s Prismatic Li-ion
VW id3/id4 55kWh, 62kWh 6.85 32 225 590 110 4.67 2.13 44.4 12s2p 0Z1 915 592 / 0Z1 915 692
VW id3/id4 82kWh 6.85 32 225 590 110 4.67 2.13 29.6 8s3p 0Z1 915 599
Toyota Prius Prime 1.76 16.9 597 152 121 9.6 6.24 70.3
Renault Kangoo 3 16 310 210 140 5.3 3.03 29.6 8s Li-ion
