Volvo V60 Battery
Revision as of 19:27, 27 August 2025 by Manny (talk | contribs) (Changed text to tables)
The Pack in the Volvo V60 D6 consists of 10 modules each made up of 10 cells. The cells are Li_ion pouch cells with a capacity of 32.5Ah. Making the modules 37V with a capacity of 1.2kWh
The BMS satellite module: LG calls them "Cell Voltage Temperature Node (CVTN).
External connector (9 pin):
Pin Function Note
1 +12V Vehicle 12V, switched by the BMS master, not regulated
2 CAN-L
3 CAN-H
4 Digital input internally 50K pulled up
5 GND only first slave has this pin connected to the master, guess for some kind of 'first slave present' detection
6 Digital output open collector with 1K in series
7 GND
8 CAN-L parallel to pin-2
9 CAN-H parallel to pin-3
Internal connector (14 pin):
Pin Function Note
1 Cell 1 positive
2 Cell 1 negative connected to main negative terminal
3 Cell 1 negative connected to main negative terminal
4 NC not connected
5 Cell 10 positive connected to main positive terminal
6 Cell 10 positive connected to main positive terminal
7 Cell 9 positive
8 Cell 2 positive
9 Cell 3 positive
10 Cell 4 positive
11 Cell 5 positive
12 Cell 6 positive
13 Cell 7 positive
14 Cell 8 positive
Forum topic on the Volvo V60 battery pack
