MG 4 Gear Selector
Revision as of 18:30, 15 August 2025 by WillK (talk | contribs)
General Information
MG 4 uses a rotary gear selector.
Neutral corresponds to the central rest postion, Reverse is selected by an anticlockwise twist, Drive by clockwise rotation of the gear knob.
Park is selected by pressing the gear knob.
Selected gear is communicated by CAN.
The unit incorporates three LEDs across the top of the unit which correspond to Reverse, Neutral and Drive.
The knob itself lights up in Yellow when Park is selected.
Part Numbers
SAIC Motor Shift-by-wire : 11357121
Pinout and Connector
The shifter uses a 12 way connector, of which only 5 pins are connected.
Required plug is:
Molex 347290122 : https://www.molex.com/en-us/products/part-detail/0347290122
When viewed from the rear of the unit, Pin1 is top-left, Pin12 is bottom right.
12-Pin Pinout
Pin OEM Wire Colour Function
1 Black/Yellow 12V
5 Pink/White 12V WakeupEnable
7 Yellow/Blue PT-CAN Ext High
8 Green/Yellow PT-CAN Ext Low
12 Black GND
CAN Bus
The Powertrain CAN Bus has a baud rate of 500kBaud.
Most messages have a standard CRC-8-SAE J1850. (polynomial 0x1D)
CanId Message 0 1 2 3 4 5 6 7
0x09D Shifter Status (from Shifter) CRC8 (bytes1-7) Counter 4-bit
F0-FF
03 POS1 POS2 F0|F1 38|39 FF
0x047 Msg1 from Controller CRC8 (bytes1-7) Counter 4-bit
00-0F
45 9B 7F FF FF FE|FF
0x12a Msg2 from Controller CRC8 (bytes1-7) Counter 4-bit
F0-FF
FF FF FF FF FF 01|11|13|14
0x2b6 Msg3 from Controller 00 00 02 00 00 00 00 00
