MG 4 Gear Selector
Revision as of 14:41, 15 August 2025 by WillK (talk | contribs) (Created page with " ==General Information== MG 4 uses a rotary gear selector. Drive, Reverse and Neutral are selected by rotating the gear knob. Park is selected by pressing the gear knob. Gear selection is communicated by CAN. === Part Numbers === SAIC Motor Shift-by-wire : 11357121 ===Pinout and Connector=== The shifter uses a 12 way connector, of which only 5 pins are connected. Required plug is: Molex 347290122 : https://www.molex.com/en-us/products/part-detail/0347290122 When vie...")
General Information
Part Numbers
When viewed from the rear of the unit, Pin1 is top-left, Pin12 is bottom right.
12-Pin Pinout
Pin OEM Wire Colour Function
1 Black/Yellow 12V
5 Pink/White 12V WakeupEnable
7 Yellow/Blue PT-CAN Ext High
8 Green/Yellow PT-CAN Ext Low
12 Black GND
CAN Bus
The Powertrain CAN Bus has a baud rate of 500kBaud.
Part Numbers
