ZombieVerter IO
Low side Outputs.
- Out1Func/GP Out 1
- Out2Func/GP Out 2
- Out3Func/GP Out 3
- Trans SL2- (If not using the GS450H)
High side PWM.
- PWM 3
- PWM 2
- PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:[edit | edit source]
- WarnIndication - OUTPUT
- HeatReq - DIGITAL INPUT:
- PWMTim3 -
- Switch_NoRegen - DIGITAL INPUT - when active throttle regen and brake regen are inhibited, this allows much easier up/down shifting if the motor is connected to a manual transmission (NOT currently in released firmware 2.22A, however will be in next release)
Proximity Pilot[edit | edit source]
