Tesla Model S GEN1 Charger
The Tesla Gen1 on-board AC charger (OBC) was a single phase 10kW AC charger that was fitted originally and primarily in the Tesla Model S, from Jun2012 through late2013*, when it was replaced with Gen2. Gen1 models are easy to identify, having the word "TESLA" stamped on the top metalwork and having no black anti-tamper tape; the Gen2 charger lacks the Tesla identifier stamped on the metalwork, and has anti-tamper tape over the seams.
One (or optionally two, in a Master/Slave configuration) Gen1 chargers are installed beneath the rear seats in the Model S for AC charging. The Single/Master OBC is on the right side of center. If two OBCs are fitted, the Second/Slave is fitted to the left of center under the rear seat; both are identical hardware, though the firmware differs.
The Gen1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, partly because they do not support 3-phase AC input. However, they are used in many OEM installations that continue to need servicing. Examples of OEM installs include Telsa (all 2012-Sep2013 Model S), Toyota (all 2012-14 RAV4 EV[1]), and Mercedes-Benz (initially "Electric Drive", later "B250e"[2], 2014-15?**). As far as is known, these are identical from a hardware perspective[3], but the firmware differs and is not interchangeable between installations.
A version of this unit was used in early Tesla Supercharger DCFC stations, with several ganged in parallel.
* The Gen2 OBCs were apparently phased in gradually. There are reports of Dec2013 with Gen1 OBCs[4], and Oct2013 with Gen2 OBCs[5][6].
** A 2016 B250e was reported to have a Gen2 OBC installed.
Charger Connectors
There are six discrete connectors on the Gen1 OBC.
- AC (Input)
- DC (Output)
- the HVIL Loop connector
Wire size * |
Telsa
Wire Color * |
| 2 ** | Charge Port: nozzle lock | "InsertEN out" | 20 AWG (0.5mm²) | YL |
| 6 ** | Fast Charge CAN | "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
| 8 | EVSE-Prox (PP) OUT | PP signal from EVSE to Drive Unit. Marked "Prox out" on Tesla's documentation, this was thought to be a "inhibit drive" signal, but testing has been inconclusive/negative for that function so far. | 22 AWG (0.35mm²) | OR-PU |
| 11 | EVSE-Prox (PP) IN | PP signal from EVSE to OBC | 20 AWG (0.5mm²) | OR |
| 12 ** | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables DCFC contactors?) | 18 AWG (0.75mm²) | RD-GY |
** = Not used on RAV4 EV.
AC Input Connector
DC Output Connector
HVIL Connector (J5)
- Tesla: The loopback harness, Tesla 1101371-00-A, is included/stored inside all Tesla Model S Gen1 Rear HVJB in an internal "parking" socket, when only a single OBC is provisioned.
Common Issues
Grounding
Fuses
Important Considerations
Output Voltage Range
| HEED DAMIEN'S WARNING:[21]
(regarding the Gen2 OBC, which may or may not apply to the Gen1) |
CAN
WIP
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
