The ZombieVerter supports popular salvaged EV parts such as:
Nissan Leaf components
Mitsubishi Outlander hybrid components
Toyota and Lexus hybrid components
CHAdeMO and CCS DC fast charging
and more!
The ZombieVerter features the following:
Hardware:
On-board WiFi
3x high side PWM drivers
5x low side outputs
3x input pins (pull to ground only)
3x CANbus interfaces
LIN bus
sync serial interface
OBD-II interface
etc.
Software:
Web based user interface
Contactor control
Charger control
Charge timer
Motor (inverter) control
Heater control
Water pump control
Coolant fan control
Throttle mapping
Motor regen
Cruise control (?)
BMS limits
IVT shunt initialization
Data logging and graphing
etc.
Pin 55 to 12V- ground
Pin 56 to 12V+ positive
general zombie and battery box wiringPin 32 to ground pin on a 12V relay
Relay positive pin to 12V+
One of the relays switch pin to 12V+
Leaf inverter enable pin
Leaf PDM enable pin
Mitsubisihi OBC enable pin
Contactor wiring
ISA IVT shunt
Nissan leaf inverter
BMW S-BOX
etc.
Pin 31 for the negative contactor
Pin 33 for the positive contactor
Pin 34 for the pre-charge contactor
Throttle pedal wiring
Pin 45 to throttle grounds
Pin 46 to throttle channel 2
Pin 47 to throttle channel 1
Pin 48 to throttle positives
Pin 15 to "on" switched input (key switched to "on")
Pin 52 to "start" momentary input (momentary key switched "ignition")
Forward and Reverse
Pin 53 reverse
Pin 54 forward
Input/output pins
Low side Outputs.
GP Out 3
GP Out 2
Neg Contactor switch/GP Out 1
Trans SL1- (If not using the GS450H)
Trans SL2- (If not using the GS450H)
High side PWM.
PWM 3
PWM 2
PWM 1
Pump PWM - Limited to GS450 Oil pump pwm or tacho pwm output
Ground Input pins
PB1
PB2
PB3
Pin functions:
Pin
IN/OUT/PWM
Function
ChaDemoAIw
OUTPUT
activates when Chademo charger handshake initiates
OBCEnable
OUTPUT
activates as part of the ExtCharger module
HeaterEnable
OUTPUT
activates only in run mode and when coolant pump is on*
RunIndication
OUTPUT
activates when zombie is in run mode
WarnIndication
OUTPUT
activates when a error occurs with the ZombieVerter
CoolantPump
OUTPUT
activates during precharge, usually used for coolant pumps
NegContactor
OUTPUT
activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
BrakeLight
OUTPUT
activates when a set brake light on threshold value is met
ReverseLight
OUTPUT
activates when reverse direction is selected
CoolingFan
OUTPUT
activates when FanTemp setpoint is reached
HVActive
OUTPUT
activates when contactors are closed and VCU is in run or charge mode
BrakeVacPump
DIGITAL OUTPUT
activates when BrakeVacSensor threshold value is met
CpSpoof
PWM OUTPUT
used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
GS450Hpump
PWM OUTPUT
used to run GS450H oil pump
HeatReq
DIGITAL INPUT
HVRequest
DIGITAL INPUT
NOT FUNCTIONING
DCFCRequest
DIGITAL INPUT
Chademo Charge Interface enable contactors to charge
ProxPilot
ANALOGUE INPUT
detects when charge cable is plugged in
BrakeVacSensor
ANALOGUE INPUT
vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
PWMTim3
Proximity Pilot
Provide stable 12V power to pins 55, 56 on the ZombieVerter
The on-board LED light "acty" should be now flashing
Using your computer, connect to the ZombieVerters WIFI access point. SSID: "inverter" or "zom_vcu"
Password is: inverter123
In a web browser navigate to: 192.168.4.1
The openinverter web interface should now load!
potmin should be set just above where your off-throttle position is
potmax just below the value seen at maximum travel
Same for pot2min and pot2max
throtmin is the minimum (most negative) allowed potnom at all times
throtmax is the maximum (most positive) allowed potnom request in forward
throtramp is how much potnom ramps up with the pedal pushed (potnom change per %/10ms)
throtramprpm stops applying throtramp above a set motor rpm
revlim is a rev limiter
Contactors
ISA
SBOX
VAG
LEAF
udcmin is the minimum battery voltage derate
udclim is maximum battery voltage derate
udcsw is Voltage point at which precharge is considered finished, and the main contactor will close.
Forward/Reverse
input options:
switch
button
switchReversed
buttomReversed
work in progress
Charger
work in progress
Input Values
Apply the Start 12V signal for a short time. The pre-charge relay should turn on, and the voltage available at the inverter and the U1 input of the ISA shunt should quickly rise. If the udc reading goes above udcsw within 5 seconds then the main contactor(s) should close. If all is well, invstat should now be "on", opmode should be "run".
Software
Initializing an ISA Shunt:
Wire the ISA shunt to 12V+ and canbus input.
Under shunt can in the web interface, select the canbus the shunt is connected to
Hit save parameters to flash.
Under Comms in the web interface, select ISAMode option. By default its set to "Normal" (Off)
Select "Init"
Power cycle the vcu and shunt at same time (they should be on same 12V feed anyway).
The shunt will initialize.
Select ISAMode "normal"
Save to flash again
Reboot the VCU
Recovering the ZombieVerter from a failed update
Firstly, download the bootloader from here and latest ZombieVerter firmware from here as .hex files. This ensures you don't need to know the address of the file and avoids user error when flashing via STLink
Download STMCubeProgrammer from here (other STM flashing softwares are available but the following instructions are based on what has worked for me).
Upgrade the firmware on your STLink dongle using STMCubeProgrammer. I'm not sure if this is 100% necessary but seems prudent.
Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the ZombieVerter test points. On the ZombieVerter Board, they are labelled C, G, D.
Connect 12V and Gnd to the ZombieVerter main power pins and ensure your STMCubeprogrammer is able to connect to it. I also disconnected the wifi board just incase.
Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
Remove your STLink from the ZombieVerter, connect the wifi board and check connectivity.
Begin ZombieVerter-ing.
ESP32 CanBus Web Interface
