Foccci
Revision as of 08:35, 27 February 2025 by Uhi22 (talk | contribs) (formatting)
Foccci (v4.5) pinout
Foccci 4.5b / 5 / 5.1 pinout
Foccci on Github.
Clara on Github.
Pin description
TEMP2 A2 A2 As above
TEMP3 A3 A3 As Above
LOCK_MOT1 A9 A9
GND A12 B12
CANH B1 B1 CAN communication
CANL B2 B2
n.c. B4
GND B5 B5, B3
LED_RED B9 A12 Status LEDs
LED_GREEN B10 A11
LED_BLUE B11 A10
Internal connectors
short name description
UART RX Not used
Foccci with (Orion) BMS
  • EvseAcCurrentLimit
  • CableCurrentLimit
Wakeup
Here are the sources:
  4. CP - Edge triggered
Basic wakeup
  2. Wakeup signal is turned on
Advanced Wakeup
Semi-advanced wakeup
Configuring Foccci via CAN
Hardware Config
UdcDivider dig/V 0 100 10 Division factor from ADC digits to V of external voltage measurement board.
Communication
Charge Parameters
Testing
Spot values
Name Unit Description
version
lasterr Last detected error
VehicleSideIsoMonAllowed This signal gives Foccci the possibility to control the isolation monitoring on vehicle side.
0: Isolation monitoring shall be off
1: Isolation monitoring shall be on (default)
Background: If we are in precharge, we tell the vehicle side isolation monitoring to keep calm, because the next step will be that the contactors close, and then the charger side isolation monitoring shall be the only one which is monitoring the isolation. Because if we would have two isolation monitors working at the same time, they could/would detection isolation faults by seeing each other. Discussion started here: https://openinverter.org/forum/viewtopic.php?p=80149#p80149
cpuload
Errors
Error Description
  • Pin 1 - GND
Hardware detection
- 47 2,7 0,179 222 216 229
- 47 3,3 0,217 269 261 277
- 47 3,9 0,253 314 304 323
- 47 4,7 0,300 372 361 383
- 47 5,1 0,323 401 389 413
- 47 5,6 0,351 436 423 449
- 47 6,8 0,417 518 502 533
- 47 7,5 0,454 564 547 580
- 47 9,1 0,535 664 644 684
4.2 47 10 0,579 718 697 740
4.3 47 12 0,671 833 808 858
4.4 47 15 0,798 991 961 1020
47 22 1,052 1306 1266 1345
47 27 1,204 1494 1449 1539
47 33 1,361 1689 1639 1740
47 39 1,497 1857 1801 1913
47 47 1,650 2048 1986 2109
47 56 1,794 2226 2160 2293
Frequently Asked Questions
Q1: Does Foccci help me for AC charging with a Tesla OBC?
Q2: Does Foccci create an 1kHz PWM, for controlling an onboard charger via the CP pin?
Q3: What is the absolute minimum to start a DC charging session?
That's it.
Q4: Besides the absolute minimum, what other features of Foccci are recommended to be used in a real-life scenario?
Q5: Can I use Foccci together with an onboard charger?
Q5: I'm missing a certain feature of Foccci, could I add this by myself?
Q6: Can I use Foccci also to build a charging station?
- generate the 1kHz PWM
- measure the CP resistance
Q7: Does Foccci support Plug&Charge or AutoCharge?
Q8: How can I find out the version of Foccci/Clara, which I am running?
Q9: I want to try out a different software version. Where can I find it?
Q10: ... Feel ... free ... to .... add ... more ... questions ... here.
Q11: ... Feel ... free ... to .... add ... more ... questions ... here.
