Water Pumps
Revision as of 23:34, 14 February 2025 by Arber333 (talk | contribs)
A list of coolant pumps
This is a list of water pumps that may be useful in an EV swap.
Pierburg CWA Coolant Pumps
CWA200
The Pierburg CWA Coolant Pumps (200/400) are well known in hot rod engine swaps as they are significant coolant pumps that have the ability to be PWM Controlled, however connecting the PWM pin to +12V permanently also gives 95% speed
Tesla Model S/X / Nissan Leaf Coolant Pump
Tesla S / X coolant pump
Tesla Model S/X Coolant Pump
Both the Model S and X use a very capable (but curiously unbranded) coolant pump. Internet research seems to indicate it may be made by VariMax, though there are so many Tesla part numbers it's hard to say which actual model it is.
The Nissan Leaf also uses this or a very similar pump.
Bosch PCE (VAG and others)
Bosch PCE Coolant Pumps
Chevrolet Volt Coolant Pumps
Coolant pump
Hyundai Kona EV Coolant Pumps
HELLA 8TW 358 304-601 Auxiliary water pump
VW coolant pump
NISSENS 831060 Water pump Auxiliary water pump
In List Form
Pump DC Voltage Current Draw Control Method Inlet Size Outlet Size Max Flow Max Pressure
CWA200 12 PWM / ON
Tesla S/X 8-16 7.3A PWM 19mm 19mm 720LPH@70kPa
Bosch PCE 12 PWM / ON
Kona EV 8-16V ~6A CAN 17 17
