Leaf stack with zombiverter
The full leaf stack ( motor/inverter, pdm (charger, dcdc, hvjb)) can be controlled with the zombieverter VCU.
All you need is 12v+, enable, and CANbus.
Wiring
Wiring the zombiverter to the leaf harness
| Description | Zombieverter Pin | PDM pin | inverter pin | |
| +12V | Permanent 12v+ | 56 | 18 | 46, 48 |
| Gnd | permanent 12v - | 55 | pdm case | 47, 49 |
| Fwd signal | Forward | 54 | ||
| Rev signal | Reverse | 53 | ||
| momentary 12V | Start signal | 52 | ||
| Brake signal | Brake Input | 49 | ||
| +5V | Throttle | 48 | ||
| Throttle signal 1 | Throttle signal 1 | 47 | ||
| Throttle signal 2 | Throttle signal 2 | 46 | ||
| Throttle Gnd | Throttle Gnd | 45 | ||
| Precharge Contactor LS Switch | Negative lead from precharge contactor | 34 | ||
| Main Contactor LS Switch | Negative lead from main contactor | 33 | ||
| enable relay | switches enable relay | 32 | 16 | 42 |
| Neg Contactor LS Switch | Negative lead from negative contactor | 31 | ||
| CANEXTH | Can 1 High | 28 | 27 | 14 |
| CANEXTL | Can 1 Low | 27 | 11 | 15 |
| T15 | Ignition 12V in | 15 | ||
| proximity pilot | pp for charge port | 29 | ||
| control pilot | cp for charge port | 30 | ||
chademo connector:
HV contactor coil - pin 10
pin 1 to ground
CAN H pin 8 to CAN EXT 3 H
CAN L pin 9 to CAN EXT 3 L
pin 4 to GP out
