ZombieVerter VCU
Revision as of 11:52, 2 February 2025 by Landsi (talk | contribs) (Front outlander drive unit is also supported - edited)
Zombiverter VCU board
Modern EV conversion projects often look to reuse salvaged parts from OEM vehicles, such as the motors, batteries and chargers.
The issue is that each part, and manufacture, use different methods of control and communication. Even when the methods of control are decoded, you are left with having to develop some sort of VCU to run the devices. These devices often talk different "languages", such as CANBUS, LINBUS, sync serial, PWM, etc
introducing: the "Zombieverter" VCU
a general purpose EV conversion VCU.
With a large array of inputs/outputs, control logic, and a web interface for configuration and data logging. The Zombieverter is a powerful, flexible and customizable VCU well suited for EV conversions. its also an open source project!
The Zombieverter supports popular salvaged EV parts such as:
  • Nissan leaf motor, PDM/OBC, and batteries
  • Mitsubishi outlander hybrid front & rear drive unit, and OBC (on board charger)
  • Lexus gs450H and gs300H hybrid gearbox's
  • chademo and ccs fast charging
  • and more!
The Zombieverter features the following:
hardware:
  • on board WIFI
  • 3x High side PWM drivers
  • 5x low side outputs
  • 3x CANbus interfaces
  • Linbus
  • sync serial interface
  • OBD-II interface
  • etc
Software:
  • web based user interface
  • contactor control
  • charger control
  • charge timer
  • motor(inverter) control
  • heater control
  • water pump control
  • coolant fan control
  • throttle mapping
  • motor regen
  • cruise control(?)
  • BMS limits
  • IVT shunt initialization
  • data logging and graphing
  • etc
Assembling the VCU
Looking to build a Zombieverter VCU your self or the kit is missing hardware?
for programming a blank board see: zombiverter programing
The enclosure kit options:
  2. Connector and pins[2]
  3. Prewired connector [3]
Wiring
zombieverter pinout from https://github.com/damienmaguire/Stm32-vcu/blob/master/Hardware/Zombie/ZombieVerter_V1%20-%20Schematic.pdf
VCU pinout diagram
each device requires different wiring setups, settings and power requirements.
wiring the zombieverter with:
Power wiring:
The Zombieverter requires permanent 12v.
This is so that it can mange charging, timers, and monitor systems when the car is at rest.
The average draw, at idle, is 150 mA.
  • pin 55 to 12v- ground
  • pin 56 to 12v+ positive
The Zombieverter controls power/ "ignition" signals to other devices (inverters, chargers, and dcdc converters) when required. This is done by triggering a external 12v relay. Low-side switching, meaning that it pulls to ground.
  • pin 32 to ground pin on a 12v relay
  • relay positive pin to 12v+
  • 1 of the relays switch pin to 12v+
This effectively provides a switched 12v supply, controlled by the Zombieverter.
Used to switch "enable" mode to devices via :
  • Leaf inverter enable pin
  • Leaf PDM enable pin
  • Mitsubisihi OBC enable pin
Contactor wiring:
The Zombieveter manages the Negative, Positive and PreCharge contactors in a ev conversion.
  • ISA IVT shunt
  • nissan leaf inverter
  • bmw SBOX
  • etc
with out a proper UDC measurement, the zombieverter will fail precharge and never go into run mode.
The contactor control pins on the Zombieverter are low-side switching, meaning that they pull to ground.
The positive leads from the contactors need to be connected to 12v+ and the ground leads to:
  • pin 31 for the negative contactor
  • pin 33 for the positive contactor
  • pin 34 for the pre-charge contactor
Throttle pedal wiring:
The Zombieverter supports dual-channel throttle, this redundancy is for safety incase one channel fails or drops out. Its highly recommended to use dual channel throttle.
single channel is an option.
Connect the following to the Zombieverter pins:
  • pin 45 to throttle grounds
  • pin 46 to throttle channel 2
  • pin 47 to throttle channel 1
  • pin 48 to throttle positives
Start, Run, and Direction wiring:
The zombieverter requires 2 inputs to get into "drive" mode. These pins need to be pulled high (connected to 12v +)
  • pin 15 to "on" switched input (key switched to "on")
  • pin 52 to "start" momentary input (momentary key switched "ignition")
Forward and Reverse:
  • pin 53 reverse
  • pin 54 forward
Input/output pins:
The Zombieverter has a number of selectable input/output pins that can be used for a number of functions. These pins are:
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
These are high side 12v outputs, usually for controlling gauges or auxiliary items than need a pwm signals.
Ground Input pins
PB1
PB2
PB3
Pin functions:
  • ChaDemoAIw - OUTPUT - activates when Chademo charger handshake initiates
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on*
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT: activates when a error occurs with the zombieverter
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates when the negative contactor needs to be closed. ie precharge, run, charge mode, etc
  • BrakeLight - OUTPUT: activates when a set brake light on threshold value is met
  • ReverseLight - OUTPUT: activates when reverse direction is selected
  • CoolingFan - OUTPUT: activates when FanTemp setpoint is reached
  • HVActive - OUTPUT: activates when contactors are closed and VCU is in run or charge mode
  • BrakeVacPump DIGITAL OUTPUT: activates when BrakeVacSensor threshold value is met
  • CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC when using a charging interface such as FOCCCI or I3LIM
  • GS450Hpump - PWM OUTPUT: used to run GS450H oil pump
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT - starts precharge cycle and puts VCU into charge mode
  • ProxPilot - ANALOGUE INPUT - detects when charge cable is plugged in
  • BrakeVacSensor - ANALOGUE INPUT - vacuum sensor input, use for triggering BrakeVacPump DIGITAL OUTPUT
  • PWMTim3 -
Proximity Pilot
Initial start-up and testing
powering up and connecting to the web interface:
The following is required:
  1. fully built Zombieverter VCU
  2. 2 wires for power
  3. 12v power supply
  4. computer/ tablet for accessing the web interface
How to access the web interface:
  1. provide stable 12v power to pins 55, 56 on the zombieverter
  2. the on-board LED light "acty" should be now flashing
  3. using your computer, connect to the zombieverters WIFI access point. SSID: "inverter" or "zom_vcu"
  4. password is: inverter123
  5. in a web browser navigate to: 192.168.4.1
  6. the openinverter web interface should now load!
Configuration:
*work in progress*
full list and overview of Zombieverter Parameters and Spot Values
basic parameters and spot values:
throttle:
  • revlim is a rev limiter
Contactors:
  • ISA
  • SBOX
  • VAG
  • LEAF
forward/reverse:
input options:
  • switch
  • button
  • switchReversed
  • buttomReversed
inverter:
charger:
Software
*VCU boards from the webshop, come pre-programed and do not require any additional septs taken to work.
Initializing an ISA Shunt:
  1. wire the ISA shunt to 12v+ and canbus input.
  2. under shunt can in the web interface, select the canbus the shunt is connected to
  3. hit save parameters to flash.
  5. select "Init"
  6. hit save parameters to flash
  7. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway).
  8. The shunt will initialize.
  9. Select ISAMode "normal"
  10. save to flash again
  11. reboot the VCU
Troubleshooting
Serial Connection
if the zombieverter fails in the middle of a software update and the Web User Interface is reporting "firmware: null" it's possible you'll need to re-flash the firmware, and bootloader via an STLink.
  1. Firstly, download the bootloader and latest zombieverter firmware from here [4] and here [5] as .hex files, this ensures you don't need to know the address of the file and avoids user error when flashing via STLink (I used a cheap STLink v2 clone without issue but it seems there is a mix of experiences with them).
  2. Download STMCubeProgrammer (other STM flashing softwares are available but the following instructions are based on what has worked for me).
  3. Upgrade the firmware on your STLink dongle using STMCubeProgrammer (I'm not sure if this is 100% necessary but seems prudent).
  4. Connect the Clock (SWclk), Gnd and Data (SWDio) of your STLink to the Zombieverter test points (near to the STM32 chip, they are labelled C, G, D) as well as 12V and Gnd to the Zombieverter main power pins and ensure your STMCubeprogrammer is able to connect to it, I also disconnected the wifi board just incase.
  5. Perform a "full chip erase", then reflash the latest bootloader and firmware hex files.
  6. Remove your STLink from the zombieverter, connect the wifi board and check connectivity.
  7. Begin Zombieverter-ing.
