MG ZS Charger
MG ZS Charger Part number(s)
| Part Number | Description | Phases | AC/DC Input 1 | AC/DC Input 2 | AC/DC Output 1 | AC/DC Output 2 | DC/DC Input | DC/DC Output |
| ZS10BC6600A (10822241) | MG ZS AC Charger | single phase | 85-265V 32A Max | N/A | 230-480V 20A Max 6.6KW Max | N/A | N/A | N/A |
| EP2CCU1130A (11276088, 11428079) | MG ZS AC Charger | three phase | 85-265V 32A Max | 85-265V 16A Max | 250-500V 24A Max | 250-500V 32A Max | 250-500V | 9-16V 220A Max@13.V |
| EP3CCU1130B (11489298) | MG 4 Charger | ??? phase | 85-265V 32A Max | 300-456V 16A Max | 220-490V 24A Max | 220-490V 31.5A Max | 220-490V | 9-16V- 220A Max@13.5V |
| EH3CCU6630B (11572315) | MG4 Trophy | ??? Phase | 85-265V 32A Max | N/A | 220-490V 22A Max | N/A | 220-490Vdc | 9-16V 220A Max@13.5V |
| EP2CCU6625A (11237810) | MG5 | ??? phase | 85-265V 32A Max | N/A | 230-450V 22A Max | N/A | 230-450Vdc 13A Max | 9-16V 178A Max@14V |
Example offer
EV Breakers - MG ZS ONBOARD BATTERY CHARGER 2019-2024 (archive.org) - 08-2024, GPB 300
https://www.bildelsbasen.se/sv-se/pb/S%C3%B6k/Bildelar/s1/MG/MG-ZS-EV/2020_2025/EL-&-Givare-&-Databox-&-Sensor/Batteriladdare-H%C3%B6gsp%C3%A4nning/_/ID-60187841/11428079 - 08-2024; 5000 SEK
Video of Damien hacking it
MG ZS EV Charger Hacked N.B It's not confirmed yet whether all chargers accept the same CAN messages for control, more investigation is needed.
MG ZS EV Charger Hacked Part 2 (Damian demonstrating ZS10BC6600A from the above list, further investigation required to see if all chargers respond to the same CAN messages)
Damien's GitHub page
https://github.com/damienmaguire/MG-EV-Charger
Connectors
| Charger part number | Low voltage | High voltage (DC) | High voltage (AC) |
| ZS10BC6600A (10822241) | 33472-1201 (housing) 33012-2021 (pin) |
2103177 (housing) 1355036 (pin) |
13879047 (housing) 13955308 (power pin) |
| EP2CCU1130A (11276088, 11428079) | 64319-1211 (housing) 64322 (0.635mm pin) |
HVC2P28FSX02 (2.5mm² Shield) HVC2P28FSX04 (4.0mm² Shield) |
HVC5P63FSx06 “X” code: CODE A:1/CODE B:2/CODE Z:0 |
ZS10BC6600A
