Tesla 16v li-ion battery
Revision as of 13:08, 22 January 2025 by Asavage (talk | contribs) (Charging:: Typo)
tesla moved from lead acid 12v batteries to a li-ion 16v battery year 2022-current for model 3 and Y. and the model S plaid
hackig thread: https://openinverter.org/forum/viewtopic.php?p=78964#p78964
info:
  • CATL prismatic Cells
  • 1p4s
  • 99 Wh
  • 4 lbs / 1.8 kg
  • 16v internally
  • LINBUS for vehicle coms on voltage, soh, crash events, etc
  • internal BMS: monitors temp, controls charge and discharge rates
  • part number 1598486-99-D
its theorized that the CATL cells are the following specs:
  • NMC
  • 6.9 Ah
  • 3.7 V nominal (4.2 V max charge voltage, 2.75 V minimum)
  • charging temperatures: from -10°C to +45°C
  • discharging temperatures: from -20°C to +60°
  • max charging: 10C
  • max peak discharging: 50C
  • cycle life: >2,000 cycles (80% of initial capacity at 3C rate)
the brains of the operation is the: mm9z1_638
part of the S12Z family of processors
The battery locks out in a crash event, and may even begin bleeding the cells to 0v for safety.
Connectors
tesla service manual info: https://service.tesla.com/docs/ModelX/ElectricalReference/prog-55/connector/x001/
housing:
EVL1-P2TJ-25WA
current pins:
85562302-01
signal/ linbus pin:
857111838-01
Charging:
If the battery is in a lock out state and will not take a charge, the cover needs to be removed to charge the battery directly.
disconnect the cell taps from the bms, and then connect a 16v power supply to the cell tabs on the bms board. The BMS will need its eeprom/firmware reset
Cover removal:
Removing the cover is required to recharge and re-flash:
remove the 4 bolts that hold cover to the the sealed connector
using a blow torch or heat gun along the edges of lid, this will soften the epoxy sealing the lid in place.
start prying with a flat head screw driver, while applying heat. the lid should release and now be free.
Software:
To reuses the battery, it needs to be reset by dumping the eeprom and re-flashing cleared firmware.
there are a few methods to go about this:
