Mitsubishi Outlander CAB300 current sensor
LEM CAB300 C/SP2 Current sensor
CAN protocol CAN bus report is fixed at 500kbps To start or stop communication it uses ID 0x6F0 in notextended(standard) frame - single signal. Signal is 8 byte long byte1 value 0x28 will stop CAN and 0x29 will start communication.
Current report is in ID 0x3C2 in standard frame 8 bytes zero center at 80000000H = 0mA 1mA = 80000001H -1mA = 7FFFFFFFH
byte0 = error indication (0 - normal, 1 - error) byte7 to byte1 is the value to calculate
CAB300 connector, which is CAB500 connector as well: 4P Female P/N 1473672-1 Pins Female Crimp 1123343-1 https://www.aliexpress.com/item/1005004210302153.html?spm=a2g0o.order_list.order_list_main.385.60b81802QTc3l6
