Toyota Prius Gen2 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control. It is also connected from the outside via the main (32 pin white) OEM connecter - try to retrieve this connecter and part of wiring loom when sourcing your inverter. Picture of connecter further down in wiki.
Functionality of the existing resolver is intergrated as well.
Wire Connections
Control Board Pinout:
| Pin # | Designation | Description |
| TB1-1 | 12v-in | Primary 12v supply from ignition on |
| TB1-2 | GND | Primary ground connection to 12v negative. All grounds are common |
| TB1-3 | 5v VCC | 5V supply from board for use with throttle pot or hall pedal |
| TB1-4 | Throttle In | 0-5v variable voltage input from throttle pedal or pot |
| TB1-5 | Regen In | 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor |
| TB1-6 | GND | |
| TB1-7 | Brake In | 12v digital input from brake light switch. |
| TB1-8 | Start In | 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used. |
| TB1-9 | For In | 12v digital input commands motor to run in forward direction |
| TB1-10 | Rev In | 12v digital input commands motor to run in reverse direction |
| TB3-1 | +12v VCC | 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it). |
| TB3-2 | GND | Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it). |
| TB3-3 | Phase U |
| TB3-4 | Phase Y | Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive |
| TB3-5 | Phase W | Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive |
| TB3-6 | Current U | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-7 | Current Y | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-8 | MG2 Enable | Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter |
| TB3-9 | MG2 Fault | Connect to MFIV for MG2 or GFIV for MG1 |
| TB3-10 | DC Bus | Connect to inverter VH to measure DC link voltage |
| TB2-1 | +5V VCC | 5v output to encoder for induction motor |
| TB2-2 | ENCA In | Encoder input A |
| TB2-3 | ENCB In | Encoder input B |
| TB2-4 | GND | Encoder ground |
| TB2-5 | HS Temp | Heatsink temp sensor input |
| TB2-6 | MOT Temp | Motor temp sensor input |
| TB4-1 | GND | Common ground |
| TB4-2 | Main Con | Main HV contactor control low side switch |
| TB4-3 | Precharge | HV precharge contactor control low side switch |
| TB4-4 | +12 V VCC | Spare 12v output |
| TB4-5 | CAN L | Can bus low signal |
| TB4-6 | CAN H | Can bus high signal |
32-pin Prius Inverter Pinout:
| Pin # | Designation | Description | Wire Color |
| 1 | NC | Not connected | |
| 2 | GIVA | MG1 Phase Current V | Example |
| 3 | GIVB | MG1 Phase Current V | Example |
| 4 | GUU | MG1 PWM U - Speed Signal Wave | Example |
| 5 | GVU | MG1 PWM V - Speed Signal Wave | Example |
| 6 | GWU | MG1 PWM W - Speed Signal Wave | Example |
| 7 | MIVA | MG2 Phase Current V | Example |
| 8 | MIVB | MG2 Phase Current V | Example |
| 9 | MUU | MG2 PWM U - Speed Signal Wave | Example |
| 10 | MVU | MG2 PWM V - Speed SIgnal Wave | Example |
| 11 | MWU | MG2 PWM W - Speed Signal Wave | Example |
| 12 | VH | Inverter Capacitor Voltage | Example |
| 13 | CPWM | Boost converter PWM switch signal | Example |
| 14 | GSDN | MG1 Shutdown | Example |
| 15 | VL | Boost converter input voltage | Example |
| 16 | GINV | Inverter Ground | Example |
| 17 | NC | Not connected | |
| 18 | GIWA | MG1 Phase Current W | Example |
| 19 | GIWB | MG1 Phase Current W | Example |
| 20 | CT | Boost converter temperature sensor | Example |
| 21 | GIVT | MG1 Inverter Temperature | Example |
| 22 | GFIV | MG1 Inverter Fail | Example |
| 23 | MIWA | MG2 Phase Current W | Example |
| 24 | MIWB | MG2 Phase Current W | Example |
| 25 | MSDN | MG2 Shutdown | Example |
| 26 | MIVT | MG2 Inverter Temperature | Example |
| 27 | MFIV | MG2 Inverter Fail | Example |
| 28 | OVH | Overvoltage | Example |
| 29 | CSDN | Boost converter shutdown signal | Example |
| 30 | FCV | Boost converter fail signal | Example |
| 31 | OVL | Boost converter over voltage signal | Example |
| 32 | GCNV | Boost converter ground | Example |
DC-DC Converter
The onboard DC-DC Converter is powered by the high voltage traction battery to supply 12v and up to 100A for low-voltage automotive components and 12 battery maintenance (plays the role of a traditional alternator). It is not designed to charge or re-charge a low 12v battery! Direct control of the converter is simple as only 1 wire is necessary to activate it, but a second can be used in addition in order to enhance control.
The 6-pin "C5" connector on the inverter needs to be wired as thus:
| 1 | ?? | 12v+ | ?? |
| 2 | Unused? | Unused? | ?? |
| 3 | Unused? | Unused? | ?? |
| 4 | NODD | 0-5v+ | Not Req. |
| 5 | VLO | Unused? | ?? |
| 6 | Unused? | Unused? | ?? |
The case of the inverter must be vehicle ground (12v battery negative terminal).
This will produce 13.2-15.2 VDC on the large C6 single-conductor connector nearby (equivalent to a car's 12v battery positive terminal), depending on voltage applied to pin 4 (if used). No base load is required to produce voltage. Pin 4, when grounded, will act a a "KILL" input and DC-DC output will drop to zero.
Note that this output is unfused and uncontrolled, and not disabled when the main inverter ignition is off (it will be on all the time unless pin 1 of the C5 connector is off). It could be tied directly to the ignition switch same as the control board ignition receives (TB1-8 on the control board ... Or should that be TB1-1/TB1-2 which is controlled by ignition???), or it could have separate power-on control if desired.
Inverter Cooling
