VAG MLBevo MQB Chargers
There's a generational difference between the 1-2 phase PHEV chargers, and the newer MLBevo type used on the Audi E-Tron, E-Tron GT & Porsche Taycan
Difference between MLBevo/MQB vs. MEB Chargers
MEB has different AC connector and therefore also different chargeport. Possibly not compatible with all the information here. The E-Tron chargers have several things which make them a bit different, one major being the LIN LED module and Door actuator, as well as only having a Hybrid CAN connection (No Drive CAN).
MLBevo/MQB Chargers Overview
There are many different variants of MQB and MLBevo chargers with a wide range of potential power outputs.
These charges are not recommended if you are looking for a known working solution.
| Part Number | Version | Power Rating | Phase | Vehicle Usage | Coolant Connections | Dimensions | Comments | Reverse Engineered | AC-Plug Connector | Communication Plug Connector | Coolant hose connector |
| 5QE915685 | 3.6kW | Single | |||||||||
| 5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | ||||||
| 5QE915682 | 3.6kW | Single | |||||||||
| 5QE915682AA
5QE915682AF |
Audi A3 8V 2018-2020 |
| 5QE915682AG | 07S | 3.6kW | Single | Audi A3 8V e-tron | Bottom | ||||||
| 5QE915682AK | 03S | 3.6kW | Single | VW Golf MK7 GTE | Bottom | Yes | |||||
| 5QE915682M | OBC C0 | 3.6kW | Single | VW Passat Hybrid | Bottom | ||||||
| 5QE915681AT | OBC 7200W | 7.2kW | Single | Audi Q7 e-tron 4M GTE | Bottom | Case not welded | |||||
| 5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba | Left side | Made by Delta, HV pass through | |||||
| 5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | Porsche Cayenne Hybrid 2017-2021 | Left side | ||||||
| 5QE915681CQ | OBCTypP072G30V03 | 7.2kW | Dual | Audi A8 PHEV 2022 | Left side | No HV pass through. | |||||
| 5QE915681B | OBC 7200W | 7.2kW | Dual | VW e-Golf 2017-2022 | Bottom | Case not welded | |||||
| 5QE915681D | OBC 7200W | 7.2kW | Dual | Audi Q5 PHEV 2020-2021 | Right side | Case not welded, no HV pass through | |||||
| 5QE915681N | OBC 7200W | 7.2kW | Dual | VW e-Crafter | Bottom | Case not welded | |||||
| 5QE915684A | 11kW | Three | Audi e-tron | Opposite End of Electrical | |||||||
| 5QE915684AD
5QE915684AT 5QE915684J |
Audi e-tron Sportback 2019-2021 |
| 5QE915684AL
Audi e-tron GT |
Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
Normaquick NW12
(unverified) | ||
| 5QE915684BC
5QE915684CM |
Normaquick NW12
(unverified) | ||
| 9J1915681AD
9J1915681AH |
Normaquick NW12
(unverified) | |
| 1EA915684AD
AC input end | 480 x 313 x 102 mm | Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic. Those are linkly not comptaible with all the information in the wiki.
Not the same as MLBevo |
LV Connection
VW part number 5Q0906379. The 60 pin signal connector is TE part number 2208272-1 .Pins are two sizes of TE pins 5-968221-1 and 1241608-6. Can be found also on Aliexpress as 60 Pin ECU connector.
| VW Golf PHEV | Seat Mii / VW e-Golf[1] | MLBevo (Audi Etron)[2] | ||||
| Pin | Function | Comment | Function | Comment | Function | Comment |
| 1 | Terminal 30 (permanent 12V) | Terminal 30 | Terminal 30 | confirmed | ||
| 2 | Charging Cover Lock (+) - Socket A | |||||
| 3 | Switch/LED Common - Socket A | confirmed / Sensor Ground / Both pin 3 and 45 can be tied together | ||||
| 4 | Charge Port RGB LED +12v o/p | LED - Red - Socket A | ||||
| 5 | Charge Port RGB LED +12v o/p | LED - Green - Socket A | ||||
| 6 | LED - Blue - Socket A | |||||
| 7 | Illumination LED - Socket A | |||||
| 8 | ||||||
| 9 | Powertrain CAN bus, high | Powertrain CAN bus, high | CAN H - Bus #1 | confirmed | ||
| 10 | Powertrain CAN bus, low | Powertrain CAN bus, low | CAN L - Bus #1 | confirmed | ||
| 11 | Hybrid CAN bus, high | Hybrid CAN bus, high | CAN H - Bus #2 | |||
| 12 | Hybrid CAN bus, low | Hybrid CAN bus, low | CAN L - Bus #2 | |||
| 13 | HVIL IN | HVIL IN | Pilot Line In | |||
| 14 | LIN Comms | |||||
| 15 | HVIL OUT | HVIL OUT | Pilot Line Out | |||
| 16 | Lock drive +. Drive to 12v to close lock. | The lock can be coded off with ODIS | Plug Lock (+) - Socket A | |||
| 17 | Lock Drive – Drive to 12v to open lock | Plug Lock (-) - Socket A | ||||
| 18 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Position - Socket A | ||||
| 19 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Ground - Socket A | ||||
| 20 | ||||||
| 21 | Immediate charge buttons | Function LED #1 | ||||
| 22 | Charge Port RGB LED +12v o/p | |||||
| 23 | Control Pilot (CP) | CP - Socket A | ||||
| 24 | Plug Present (PP) (4.7K to ground in socket) | PP/CS - Socket A | ||||
| 25 | Immediate charge buttons | Charge Button - Socket A | ||||
| 26 | Search Light (Shared - Possible LED4 in config) | |||||
| 27 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (-) - Socket A | ||||
| 28 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (+) - Socket A | ||||
| 29 | Charging Cover Position Switch - Socket A | |||||
| 30 | AC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
| 31 | Charge port door lock actuator | The flap can be coded off with ODIS | Charging Cover Lock (+) - Socket B | |||
| 32 | Charge port door lock actuator | Charging Cover Lock (-) - Socket B | ||||
| 33 | Charge port door lock actuator | Charging Cover Position Switch - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
| 34 | Charge port door lock actuator | |||||
| 35 | Switch/LED Common - Socket B | confirmed | ||||
| 36 | LED - Red - Socket B | confirmed | ||||
| 37 | LED - Green - Socket B | confirmed | ||||
| 38 | LED - Blue - Socket B | confirmed | ||||
| 39 | Illumination LED - Socket B | confirmed / Other side tied to ground pin* (Debating if this should be tied to the 3/45 pins) | ||||
| 40 | CP - Socket B | confirmed | ||||
| 41 | PP/CS - Socket B | confirmed | ||||
| 42 | ||||||
| 43 | ||||||
| 44 | ||||||
| 45 | Switch/LED Common - Socket B | confirmed / Both pin 3 and 45 can be tied together | ||||
| 46 | Plug Lock (+) - Socket B | confirmed | ||||
| 47 | Plug Lock (-) - Socket B | confirmed | ||||
| 48 | Plug Lock Position - Socket B | confirmed / Resistive 1k/11k unlocked/locked) *Other side tied to sensor ground pins 3/45* | ||||
| 49 | DC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
| 50 | Charging Cover Lock (-) - Socket A | |||||
| 51 | Immediate charge buttons | Charge Button - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
| 52 | DC Charge Port Temperature Sensor (-) - Socket B | confirmed | ||||
| 53 | Chademo CAN-H | |||||
| 54 | Chademo CAN-L | |||||
| 55 | Chademo | |||||
| 56 | Chademo | |||||
| 57 | ||||||
| 58 | ||||||
| 59 | ||||||
| 60 | Terminal 31 (Ground) | Terminal 31 | confirmed | |||
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
MLBevo
TE YHVA630-5phm-6mm-A and HV output coding A is 2141256-1
HV Connection
It doesnt care what you connect to the HV wires. 360v, 12v, heating element, dead short. Its mission in life is pumping current. It just dumps out voltage even when it does not see any voltage present.
Coding
LIN Devices still show up within the DTC Memory, However no functional issues with them disconnected as long as the coding has them coded out. Similar errors exist for the door and other coded out options. Assumption is that the base software still has the DTC codes enabled for faults, however the selection is universal for the base charger option. (much like how most times you can code out a O2 sensor, but the DTC code will remain unless digging deeper into the ECU programming)
VCDS
| Bitfield 0 | Bitfield 1 | Bitfield 2 | Bitfield 3 |
| CP standard - SAE/
Country encoding (NAR/
Mobile Online Services (MOD)
Charging cover lock detection (charging socket B)
| Bitfield 4 | Bitfield 5 | Bitfield 6 | Bitfield 7 |
| Plug and Charge (PnC)
Variant coding 11 kW (reserve)
DC China socket installed
Installation location DC charging socket |
ODIS
ODIS Engineering is a common tool that works with some of the simpler dongles e.g. a VAS6154 cable
PIWIS
CAN-Messages
MLBevo TX Messages:
The CAN signals for MLBevo appear to be totally different than those for the rest of the charger line.
Required:
- BMS_01 - 0x191
- BMS_02 - 0x1A1
- BMS_03 - 0x39D
- BMS_04 - 0x5A2
- BMS_06 - 0x59E
- BMS_07 - 0x5CA
- BMS_09 - 0x96A955EB
- BMS_10 - 0x509
- BMS_11 - 0x96A954A6
- BMS_27 - 0x9A555552
Signals I'm sending In addition:
Signals I haven't added:
- Dimmung_01 - 0x5F0
- Einheiten_01 - 0x643
Narrowed down to:
10ms:
0x191
100ms:
0x3C0
0x503
0x1A1
MQB TX Messages:
Golf Phev charger from a CAN perspective are a total of 7 messages. One on PT CAN : 0x187 and 6 on Hybrid CAN : 0x097 , 0x124 , 0x3a6 , 0x3af , 0x6a3 and 0x6a4.
Reference Implementations:
| Charger | Code | References | Status | Comment |
| Audi E-Tron Charger (11kW) | [3] | Proved working | Mitchy | |
| 7.2kW Cayenne Phev charger 5QE 915 681 BQ | Arduino[4], ZombieVCU[5] | [6] | Proved working | LRBen |
| 2021 Seat Mii part number : 5QE915681BP
Golf PHEV part number : 5QE915682AK |
Arduino | Proved Working | Damien |
- ↑ https://www.youtube.com/watch?v=k1KUErQxx5M
- ↑ https://openinverter.org/forum/viewtopic.php?p=61370#p61370
- ↑ https://github.com/SomersetEV/Stm32-vcu/tree/Cayenne-Charger
- ↑ https://openinverter.org/forum/viewtopic.php?p=61070#p61070
