VAG MLBevo MQB Chargers
There's a generational difference between the 1-2 phase PHEV chargers, and the newer MLBevo type used on the Audi E-Tron, E-Tron GT & Porsche Taycan
Difference between MLBevo/MQB vs. MEB Chargers
MLBevo/MQB Chargers Overview
There are many different variants of MQB and MLBevo chargers with a wide range of potential power outputs.
These charges are not recommended if you are looking for a known working solution.
Part Number | Version | Power Rating | Phase | Vehicle Usage | Coolant Connections | Dimensions | Comments | Reverse Engineered | AC-Plug Connector | Communication Plug Connector | Coolant hose connector |
5QE915685 | 3.6kW | Single | |||||||||
5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | ||||||
5QE915682 | 3.6kW | Single | |||||||||
5QE915682AA
5QE915682AF |
Audi A3 8V 2018-2020 |
5QE915682AG | 07S | 3.6kW | Single | Audi A3 8V e-tron | Bottom | ||||||
5QE915682AK | 03S | 3.6kW | Single | VW Golf MK7 GTE | Bottom | Yes | |||||
5QE915682M | OBC C0 | 3.6kW | Single | VW Passat Hybrid | Bottom | ||||||
5QE915681AT | OBC 7200W | 7.2kW | Single | Audi Q7 e-tron 4M GTE | Bottom | Case not welded | |||||
5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba | Left side | Made by Delta, HV pass through | |||||
5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | Porsche Cayenne Hybrid 2017-2021 | Left side | ||||||
5QE915681CQ | OBCTypP072G30V03 | 7.2kW | Dual | Audi A8 PHEV 2022 | Left side | No HV pass through. | |||||
5QE915681B | OBC 7200W | 7.2kW | Dual | VW e-Golf 2017-2022 | Bottom | Case not welded | |||||
5QE915681D | OBC 7200W | 7.2kW | Dual | Audi Q5 PHEV 2020-2021 | Right side | Case not welded, no HV pass through | |||||
5QE915681N | OBC 7200W | 7.2kW | Dual | VW e-Crafter | Bottom | Case not welded | |||||
5QE915684A | 11kW | Three | Audi e-tron | Opposite End of Electrical | |||||||
5QE915684AD
5QE915684AT 5QE915684J |
Audi e-tron Sportback 2019-2021 |
5QE915684AL
Audi e-tron GT |
Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
5QE915684BJ | OBCTYPP110G10V04 | 11kW | Three | Audi e-tron(?) | Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
5QE915684BC
5QE915684CM |
Normaquick NW12
(unverified) | ||
9J1915681AD
9J1915681AH |
Normaquick NW12
(unverified) | |
1EA915684AD
AC input end | 480 x 313 x 102 mm | Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic. Those are linkly not comptaible with all the information in the wiki.
Not the same as MLBevo |
LV Connection
VW part number 5Q0906379. Pins are two sizes of TE pins 5-968221-1 and 1241608-6.
VW Golf PHEV | Seat Mii / VW e-Golf[1] | MLBevo (Audi Etron)[2] | ||||
Pin | Function | Comment | Function | Comment | Function | Comment |
1 | Terminal 30 (permanent 12V) | Terminal 30 | Terminal 30 | confirmed | ||
2 | Charging Cover Lock (+) - Socket A | |||||
3 | Switch/LED Common - Socket A | confirmed / Sensor Ground / Both pin 3 and 45 can be tied together | ||||
4 | Charge Port RGB LED +12v o/p | LED - Red - Socket A | ||||
5 | Charge Port RGB LED +12v o/p | LED - Green - Socket A | ||||
6 | LED - Blue - Socket A | |||||
7 | Illumination LED - Socket A | |||||
8 | ||||||
9 | Powertrain CAN bus, high | Powertrain CAN bus, high | CAN H - Bus #1 | confirmed | ||
10 | Powertrain CAN bus, low | Powertrain CAN bus, low | CAN L - Bus #1 | confirmed | ||
11 | Hybrid CAN bus, high | Hybrid CAN bus, high | CAN H - Bus #2 | |||
12 | Hybrid CAN bus, low | Hybrid CAN bus, low | CAN L - Bus #2 | |||
13 | HVIL IN | HVIL IN | Pilot Line In | |||
14 | LIN Comms | |||||
15 | HVIL OUT | HVIL OUT | Pilot Line Out | |||
16 | Lock drive +. Drive to 12v to close lock. | The lock can be coded off with ODIS | Plug Lock (+) - Socket A | |||
17 | Lock Drive – Drive to 12v to open lock | Plug Lock (-) - Socket A | ||||
18 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Position - Socket A | ||||
19 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Ground - Socket A | ||||
20 | ||||||
21 | Immediate charge buttons | Function LED #1 | ||||
22 | Charge Port RGB LED +12v o/p | |||||
23 | Control Pilot (CP) | CP - Socket A | ||||
24 | Plug Present (PP) (4.7K to ground in socket) | PP/CS - Socket A | ||||
25 | Immediate charge buttons | Charge Button - Socket A | ||||
26 | Search Light (Shared - Possible LED4 in config) | |||||
27 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (-) - Socket A | ||||
28 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (+) - Socket A | ||||
29 | Charging Cover Position Switch - Socket A | |||||
30 | AC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
31 | Charge port door lock actuator | The flap can be coded off with ODIS | Charging Cover Lock (+) - Socket B | |||
32 | Charge port door lock actuator | Charging Cover Lock (-) - Socket B | ||||
33 | Charge port door lock actuator | Charging Cover Position Switch - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
34 | Charge port door lock actuator | |||||
35 | Switch/LED Common - Socket B | confirmed | ||||
36 | LED - Red - Socket B | confirmed | ||||
37 | LED - Green - Socket B | confirmed | ||||
38 | LED - Blue - Socket B | confirmed | ||||
39 | Illumination LED - Socket B | confirmed / Other side tied to ground pin* (Debating if this should be tied to the 3/45 pins) | ||||
40 | CP - Socket B | confirmed | ||||
41 | PP/CS - Socket B | confirmed | ||||
42 | ||||||
43 | ||||||
44 | ||||||
45 | Switch/LED Common - Socket B | confirmed / Both pin 3 and 45 can be tied together | ||||
46 | Plug Lock (+) - Socket B | confirmed | ||||
47 | Plug Lock (-) - Socket B | confirmed | ||||
48 | Plug Lock Position - Socket B | confirmed / Resistive 1k/11k unlocked/locked) *Other side tied to sensor ground pins 3/45* | ||||
49 | DC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
50 | Charging Cover Lock (-) - Socket A | |||||
51 | Immediate charge buttons | Charge Button - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
52 | DC Charge Port Temperature Sensor (-) - Socket B | confirmed | ||||
53 | Chademo CAN-H | |||||
54 | Chademo CAN-L | |||||
55 | Chademo | |||||
56 | Chademo | |||||
57 | ||||||
58 | ||||||
59 | ||||||
60 | Terminal 31 (Ground) | Terminal 31 | confirmed |
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
MLBevo
TE YHVA630-5phm-6mm-A and HV output coding A is 2141256-1
HV Connection
Coding
LIN Devices still show up within the DTC Memory, However no functional issues with them disconnected as long as the coding has them coded out. Similar errors exist for the door and other coded out options. Assumption is that the base software still has the DTC codes enabled for faults, however the selection is universal for the base charger option. (much like how most times you can code out a O2 sensor, but the DTC code will remain unless digging deeper into the ECU programming)
VCDS
Bitfield 0 | Bitfield 1 | Bitfield 2 | Bitfield 3 |
CP standard - SAE/
Country encoding (NAR/
Mobile Online Services (MOD)
Charging cover lock detection (charging socket B)
Bitfield 4 | Bitfield 5 | Bitfield 6 | Bitfield 7 |
Plug and Charge (PnC)
Variant coding 11 kW (reserve)
DC China socket installed
Installation location DC charging socket |
ODIS
ODIS Engineering is a common tool that works with some of the simpler dongles e.g. a VAS6154 cable
PIWIS
CAN-Messages
RX Messages:
TX Messages:
Required:
- BMS_01 - 0x191
- BMS_02 - 0x1A1
- BMS_03 - 0x39D
- BMS_04 - 0x5A2
- BMS_06 - 0x59E
- BMS_07 - 0x5CA
- BMS_09 - 0x96A955EB
- BMS_10 - 0x509
- BMS_11 - 0x96A954A6
- BMS_27 - 0x9A555552
Signals I'm sending In addition:
Signals I haven't added:
- Dimmung_01 - 0x5F0
- Einheiten_01 - 0x643
Reference Implementations:
Charger | Code | References | Status | Comment |
Audi E-Tron Charger (11kW) | [3] | Proved working | Mitchy | |
7.2kW Cayenne Phev charger 5QE 915 681 BQ | Arduino[4], ZombieVCU[5] | [6] | Proved working | LRBen |
- ↑ https://www.youtube.com/watch?v=k1KUErQxx5M
- ↑ https://openinverter.org/forum/viewtopic.php?p=61370#p61370
- ↑ https://github.com/SomersetEV/Stm32-vcu/tree/Cayenne-Charger
- ↑ https://openinverter.org/forum/viewtopic.php?p=61070#p61070
