VAG MLBevo MQB Chargers
There's a generational difference between the 1-2 phase PHEV chargers, and the newer MLBevo type used on the Audi E-Tron, E-Tron GT & Porsche Taycan
Difference between MLBevo/MQB vs. MEB Chargers
MLBevo/MQB Chargers Overview
There are many different variants of MQB and MLBevo chargers with a wide range of potential power outputs.
These charges are not recommended if you are looking for a known working solution.
| Part Number | Version | Power Rating | Phase | Vehicle Usage | Coolant Connections | Dimensions | Comments | Reverse Engineered | AC-Plug Connector | Communication Plug Connector | Coolant hose connector |
| 5QE915685 | 3.6kW | Single | |||||||||
| 5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | ||||||
| 5QE915682 | 3.6kW | Single | |||||||||
| 5QE915682AA
5QE915682AF |
Audi A3 8V 2018-2020 |
| 5QE915682AG | 07S | 3.6kW | Single | Audi A3 8V e-tron | Bottom | ||||||
| 5QE915682AK | 03S | 3.6kW | Single | VW Golf MK7 GTE | Bottom | Yes | |||||
| 5QE915682M | OBC C0 | 3.6kW | Single | VW Passat Hybrid | Bottom | ||||||
| 5QE915681AT | OBC 7200W | 7.2kW | Single | Audi Q7 e-tron 4M GTE | Bottom | Case not welded | |||||
| 5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba | Left side | Made by Delta, HV pass through | |||||
| 5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | Porsche Cayenne Hybrid 2017-2021 | Left side | ||||||
| 5QE915681CQ | OBCTypP072G30V03 | 7.2kW | Dual | Audi A8 PHEV 2022 | Left side | No HV pass through. | |||||
| 5QE915681B | OBC 7200W | 7.2kW | Dual | VW e-Golf 2017-2022 | Bottom | Case not welded | |||||
| 5QE915681D | OBC 7200W | 7.2kW | Dual | Audi Q5 PHEV 2020-2021 | Right side | Case not welded, no HV pass through | |||||
| 5QE915681N | OBC 7200W | 7.2kW | Dual | VW e-Crafter | Bottom | Case not welded | |||||
| 5QE915684A | 11kW | Three | Audi e-tron | Opposite End of Electrical | |||||||
| 5QE915684AD
5QE915684AT 5QE915684J |
Audi e-tron Sportback 2019-2021 |
| 5QE915684AL
Audi e-tron GT |
Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
Normaquick NW12
(unverified) | ||
| 5QE915684BC
5QE915684CM |
Normaquick NW12
(unverified) | ||
| 9J1915681AD
9J1915681AH |
Normaquick NW12
(unverified) | |
| 1EA915684AD
AC input end | 480 x 313 x 102 mm | Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic.
LV Connection
| VW Golf PHEV | Seat Mii / VW e-Golf[2] | MLBevo (Audi Etron)[3] | ||||
| Pin | Function | Comment | Function | Comment | Function | Comment |
| 1 | Terminal 30 (permanent 12V) | Terminal 30 | Terminal 30 | confirmed | ||
| 2 | Charging Cover Lock (+) - Socket A | |||||
| 3 | Switch/LED Common - Socket A | confirmed / Sensor Ground / Both pin 3 and 45 can be tied together | ||||
| 4 | Charge Port RGB LED +12v o/p | LED - Red - Socket A | ||||
| 5 | Charge Port RGB LED +12v o/p | LED - Green - Socket A | ||||
| 6 | LED - Blue - Socket A | |||||
| 7 | Illumination LED - Socket A | |||||
| 8 | ||||||
| 9 | Powertrain CAN bus, high | Powertrain CAN bus, high | CAN H - Bus #1 | confirmed | ||
| 10 | Powertrain CAN bus, low | Powertrain CAN bus, low | CAN L - Bus #1 | confirmed | ||
| 11 | Hybrid CAN bus, high | Hybrid CAN bus, high | CAN H - Bus #2 | |||
| 12 | Hybrid CAN bus, low | Hybrid CAN bus, low | CAN L - Bus #2 | |||
| 13 | HVIL IN | HVIL IN | Pilot Line In | |||
| 14 | LIN Comms | |||||
| 15 | HVIL OUT | HVIL OUT | Pilot Line Out | |||
| 16 | Lock drive +. Drive to 12v to close lock. | The lock can be coded off with ODIS | Plug Lock (+) - Socket A | |||
| 17 | Lock Drive – Drive to 12v to open lock | Plug Lock (-) - Socket A | ||||
| 18 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Position - Socket A | ||||
| 19 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Ground - Socket A | ||||
| 20 | ||||||
| 21 | Immediate charge buttons | Function LED #1 | ||||
| 22 | Charge Port RGB LED +12v o/p | |||||
| 23 | Control Pilot (CP) | CP - Socket A | ||||
| 24 | Plug Present (PP) (4.7K to ground in socket) | PP/CS - Socket A | ||||
| 25 | Immediate charge buttons | Charge Button - Socket A | ||||
| 26 | Search Light (Shared - Possible LED4 in config) | |||||
| 27 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (-) - Socket A | ||||
| 28 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (+) - Socket A | ||||
| 29 | Charging Cover Position Switch - Socket A | |||||
| 30 | AC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
| 31 | Charge port door lock actuator | The flap can be coded off with ODIS | Charging Cover Lock (+) - Socket B | |||
| 32 | Charge port door lock actuator | Charging Cover Lock (-) - Socket B | ||||
| 33 | Charge port door lock actuator | Charging Cover Position Switch - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
| 34 | Charge port door lock actuator | |||||
| 35 | Switch/LED Common - Socket B | confirmed | ||||
| 36 | LED - Red - Socket B | confirmed | ||||
| 37 | LED - Green - Socket B | confirmed | ||||
| 38 | LED - Blue - Socket B | confirmed | ||||
| 39 | Illumination LED - Socket B | confirmed / Other side tied to ground pin* (Debating if this should be tied to the 3/45 pins) | ||||
| 40 | CP - Socket B | confirmed | ||||
| 41 | PP/CS - Socket B | confirmed | ||||
| 42 | ||||||
| 43 | ||||||
| 44 | ||||||
| 45 | Switch/LED Common - Socket B | confirmed / Both pin 3 and 45 can be tied together | ||||
| 46 | Plug Lock (+) - Socket B | confirmed | ||||
| 47 | Plug Lock (-) - Socket B | confirmed | ||||
| 48 | Plug Lock Position - Socket B | confirmed / Resistive 1k/11k unlocked/locked) *Other side tied to sensor ground pins 3/45* | ||||
| 49 | DC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
| 50 | Charging Cover Lock (-) - Socket A | |||||
| 51 | Immediate charge buttons | Charge Button - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
| 52 | DC Charge Port Temperature Sensor (-) - Socket B | confirmed | ||||
| 53 | Chademo CAN-H | |||||
| 54 | Chademo CAN-L | |||||
| 55 | Chademo | |||||
| 56 | Chademo | |||||
| 57 | ||||||
| 58 | ||||||
| 59 | ||||||
| 60 | Terminal 31 (Ground) | Terminal 31 | confirmed | |||
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
HV Connection
Coding
MLBevo chargers seem to all use the EV_OBC3Phase1KLOMLBev16B config/odx
VCDS
You can open in the VCDS LCode.exe program (no purchase needed) and it's a interactive way to determine the coding value required. Coding label file available here. Shouldn't be necessary for newer versions of VCDS.
| Bitfield 0 | Bitfield 1 | Bitfield 2 | Bitfield 3 |
| CP standard - SAE/
Country encoding (NAR/
Mobile Online Services (MOD)
Charging cover lock detection (charging socket B)
| Bitfield 4 | Bitfield 5 | Bitfield 6 | Bitfield 7 |
| Plug and Charge (PnC)
Variant coding 11 kW (reserve)
DC China socket installed
Installation location DC charging socket |
ODIS
PIWIS
CAN-Messages
RX Messages:
TX Messages:
Required:
- BMS_01 - 0x191
- BMS_02 - 0x1A1
- BMS_03 - 0x39D
- BMS_04 - 0x5A2
- BMS_06 - 0x59E
- BMS_07 - 0x5CA
- BMS_09 - 0x96A955EB
- BMS_10 - 0x509
- BMS_11 - 0x96A954A6
- BMS_27 - 0x9A555552
Signals I'm sending In addition:
Signals I haven't added:
- Dimmung_01 - 0x5F0
- Einheiten_01 - 0x643
Reference Implementations:
- ↑ From Forum Reference: https://openinverter.org/forum/viewtopic.php?p=47620#p47620 VW Parts Store:https://parts.vw.com/p/Volkswagen__/Housing/64431217/5Q0906379.html (Backup: Web Archive)
