EV Conversion Parts
Motors
AC Induction Motors
- Siemens 1PV5135-4WS14
PMSM (Permanent Magnet Synchronous Motors)
These Requires FOC Firmware.
- Nissan Leaf EM57 (Gen 2)
- Nissan Leaf EM61 (Gen 1)
- Remy HVH-250
There is a more general motor list as well.
Batteries
See the Batteries page for additional information.
CALB
LG Chem - BMW Hybrid
LG Chem - BMW I3
LG Chem - Chevy Volt
LG Chem - Chrysler Pacifica Hybrid
Tesla
Brakes
Vacuum Boosted
Vacuum Pumps
Vacuum pumps are available via several OEM and 3rd party manufacturers. Some options may include:
- Leed Brakes Bandit series (apparently runs quiet)
- Aeroflow Performance Twin Piston Vacuum Pump Kit
- The VAG 1J0612181B is a cheap and readily available pump used by VAG cars.
- These us 3 pins: +12v, Gnd and a sensing wire, which when brought to ground stops the pump.
- The part number for the relay on the side is: 1j0919433b
- The part number for the relay's connector is: 1J0 973 733
Vacuum Sensors:
- BOSCH 0 265 005 331 / 13581083
- Pin 3 - 5V
- Pin 2 - Gnd
- Pin 1 - Value - 0.48v under no vacuum
- Seems to have checkvalve built in.
Electrically Boosted:
There are a couple of options for electrically boosted braking systems, with one of the most popular being the Bosch iBooster.
More info on using the iBooster is available here, and pinouts for the Tesla versions here
While the iBooster will provide brake assist with no inputs (failsafe mode), more sophisticated control (and integration with other systems) is possible using a CAN-based controller such as this one from Seb Smith.
iBooster gen1 connectors:
Main connector (26-pin): Bosch "EuCon" 26p
- Main housing: 1928405762
- Cover: 1928405765
- Pins: Bosch BTC Terminal
- 1928498807 - BTC 4.8 / Terminal Sn / > 2.5 - 4.0 mm² (main power: pins 1 & 9)
- 1928498806 - BTC 2.8 / Terminal Sn / 1.5 - 2.5 mm² (constant power: pin 17)
- 1928498705 - BTC 1.5 / Terminal Sn / 0.35 - 0.5 mm² (ignition power: pin 20; signal pins 2, 8, 22, 23)
- 1928498805 - BTC 1.5 / Terminal Sn / 0.5 - 1.0 mm² (larger diameter alternative to 1928498705 above)
- Seals: Bosch BTC
- 1928301086 - BTC 4.8 / Seal / Blue (∅ 3.4 - ∅ 3.7 mm)
- 1928301206 - BTC 2.8 / Seal / Reddish Brown (∅ 2.0 - ∅ 2.7 mm)
- 1928301083 - BTC 1.5 / Seal / Grey (∅ 1.6 - ∅ 1.9 mm)
- Plugs: Bosch BTC
- 1928301207 - BTC 2.8 / Plug / Green
- 1928301087 - BTC 1.5 / Plug / White
Sensor connector (4-pin): TE MQS
- Housing: 1-967640-1
- Pins: 5-965906-5 (20 - 18 AWG)
- Seals: 1-967067-1 (∅ 1.4 - ∅ 2.1 mm)
iBooster Sourcing
| Part Number | Generation | Models available in |
| 5QE614105AH | Volkswagen e-Golf (2016-2018)
Audi A3 Sportback e-tron (2017) | |
| 5QE614105AK | Gen 1 | Volkswagen e-Golf (2016-2018)
Volkswagen Passat GTE (2017) Volkswagen Golf GTE (2017) |
| 5QE614105AN | Gen 2 | Volkswagen e-Golf (2018-2019) |
| 5QE614105AQ | Gen 2 | Volkswagen e-Golf (2018-2019) |
| 5QE614105S | Volkswagen e-Golf (2016-2018)
| 1037123-00-A | Gen 1 | Tesla Model S
Tesla Model X |
| 1037123-00-B | Gen 1 | Tesla Model S
Tesla Model X |
| 1044671-00-D | Tesla Model 3 | |
| 1044671-00-E | Gen 2 | Tesla Model 3 |
An alternative list (mostly the same) of iBooster donors can be found here: https://www.evcreate.nl/ibooster-donor-vehicles/
Charger
Built-In
Chevy Volt / Lear
Tesla Gen 2 10kW(?)
Tesla PCS
Contactors
DC/DC
Chevy Volt / Lear
Prius Inverters
tesla model s
High Voltage Junction Box
Building a junction box
Power Steering
Opel Electric Power Steering Column
