The Status cell will have several status like:
- Suggested,
- Approved, looks good go ahead and put in firmware
- STD, is established and standard in firmware
Sign with your forum name, please do not delete any rows, just add a new.
Openiverter CAN data out.
| Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Status
Sign
| Inv. temp
0x3FF
0-255
-128 to 127
Suggested
joromy
| Motor temp
0x3FF
0-255
-128 to 127
Suggested
joromy
| AUX volt
0x3FF
LSB
MSB
12V battery
Suggested
joromy
| N/P
0x3FF
0
Suggested
joromy
| FWD
0x3FF
1
Suggested
joromy
| REW
0x3FF
15
Suggested
joromy
| Motor ON
0x3FF
1
ON-1, OFF-0
Suggested
joromy
Simp BMS CAN data out.
| Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Satus
Sign
| SOC
0x355
0-100
STD
joromy
| BMS Boot
0x355
0
Status
Suggested
joromy
| BMS Ready
0x355
1
Status
Suggested
joromy
| BMS Drive
0x355
2
Status
Suggested
joromy
| BMS Charge
0x355
3
Status
Suggested
joromy
| BMS Precharge
0x355
4
Status
Suggested
joromy
| BMS Error
0x355
5
Status
Suggested
joromy
| BMS Heat/cool
0x355
6
Staus
Suggested
joromy
| Pack Volt
0x356
LSB
MSB
STD
joromy
| Tot. Amps
0x356
LSB
MSB
STD
joromy
| Avg. celltemp
0x356
LSB
MSB
STD
joromy
| Lo cellvolt
0x373
LSB
MSB
Suggested
joromy
| Hi cellvolt
0x373
LSB
MSB
Suggested
joromy
| Lo celltemp
0x373
LSB
MSB
Suggested
joromy
| HI celltemp
0x373
LSB
MSB
Suggested
joromy
Tesla charger CAN data out (only DUE based board)
| Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Status
Sign
| Unconnected
0x3D8
0
Suggested
joromy
| Buttonpress
0x3D8
1
Suggested
joromy
| Connected
0x3D8
2
Suggested
joromy
| EVSE disable
0x3D8
0
Normal mode
Suggested
joromy
| EVSE enable
0x3D8
1
AC enable, no charge
Suggested
joromy
