VAG MLBevo MQB Chargers
MEB Chargers
There are many different variants of MQB and MEB chargers with a wide range of potential power outputs.
| Part Number | Version | Power Rating | Phase | Vehicle Usage | Coolant Connections | Dimensions | Comments | Reverse Engineered |
| 5QE915685 | 3.6kW | Single | ||||||
| 5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | |||
| 5QE915682 | 3.6kW | Single | ||||||
| 5QE915682AA
5QE915682AF |
Audi A3 8V 2018-2020 |
Bottom | Case not welded, 2 HV pass throughs | ||
| 5QE915682AG | 07S | 3.6kW | Single | Audi A3 8V e-tron | Bottom | |||
| 5QE915682AK | 03S | 3.6kW | Single | VW Golf MK7 GTE | Bottom | Yes | ||
| 5QE915682M | OBC C0 | 3.6kW | Single | VW Passat Hybrid | Bottom | |||
| 5QE915681AT | OBC 7200W | 7.2kW | Single | Audi Q7 e-tron 4M GTE | Bottom | Case not welded | ||
| 5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba | Left side | Made by Delta, HV pass through | ||
| 5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | Porsche Cayenne Hybrid 2017-2021 | Left side | |||
| 5QE915681CQ | OBCTypP072G30V03 | 7.2kW | Dual | Audi A8 PHEV 2022 | Left side | No HV pass through. | ||
| 5QE915681B | OBC 7200W | 7.2kW | Dual | VW e-Golf 2017-2022 | Bottom | Case not welded | ||
| 5QE915681D | OBC 7200W | 7.2kW | Dual | Audi Q5 PHEV 2020-2021 | Right side | Case not welded, no HV pass through | ||
| 5QE915681N | OBC 7200W | 7.2kW | Dual | VW e-Crafter | Bottom | Case not welded | ||
| 5QE915684A | 11kW | Three | Audi e-tron | Opposite End of Electrical | ||||
| 5QE915684AD
5QE915684AT 5QE915684J |
Audi e-tron Sportback 2019-2021 |
| 5QE915684AL
Audi e-tron GT |
Right Side | Made by KOSTAL
| 5QE915684BC
5QE915684CM |
| 9J1915681AD
9J1915681AH |
| 1EA915684AD
AC input end | 480 x 313 x 102 mm | Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic.
Pinouts
| VW Golf PHEV | Seat Mii / VW e-Golf[2] | |||
| Pin | Function | Comment | Function | Comment |
| 1 | Terminal 30 (permanent 12V) | Terminal 30 | ||
| 2 | ||||
| 3 | ||||
| 4 | Charge Port RGB LED +12v o/p | |||
| 5 | Charge Port RGB LED +12v o/p | |||
| 6 | ||||
| 7 | ||||
| 8 | ||||
| 9 | Powertrain CAN bus, high | Powertrain CAN bus, high | ||
| 10 | Powertrain CAN bus, low | Powertrain CAN bus, low | ||
| 11 | Hybrid CAN bus, high | Hybrid CAN bus, high | ||
| 12 | Hybrid CAN bus, low | Hybrid CAN bus, low | ||
| 13 | HVIL IN | HVIL IN | ||
| 14 | ||||
| 15 | HVIL OUT | HVIL OUT | ||
| 16 | Lock drive +. Drive to 12v to close lock. | |||
| 17 | Lock Drive – Drive to 12v to open lock | |||
| 18 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. | |||
| 19 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. | |||
| 20 | ||||
| 21 | Immediate charge buttons | |||
| 22 | Charge Port RGB LED +12v o/p | |||
| 23 | Control Pilot (CP) | |||
| 24 | Plug Present (PP) | |||
| 25 | Immediate charge buttons | |||
| 26 | ||||
| 27 | Temperature sender for charging socket. 1067R at approx 15C | |||
| 28 | Temperature sender for charging socket. 1067R at approx 15C | |||
| 29 | ||||
| 30 | ||||
| 31 | Charge port door lock actuator | |||
| 32 | Charge port door lock actuator | |||
| 33 | Charge port door lock actuator | |||
| 34 | Charge port door lock actuator | |||
| 35 | ||||
| 36 | ||||
| 37 | ||||
| 38 | ||||
| 39 | ||||
| 40 | ||||
| 41 | ||||
| 42 | ||||
| 43 | ||||
| 44 | ||||
| 45 | ||||
| 46 | ||||
| 47 | ||||
| 48 | ||||
| 49 | ||||
| 50 | ||||
| 51 | Immediate charge buttons | |||
| 52 | ||||
| 53 | ||||
| 54 | ||||
| 55 | ||||
| 56 | ||||
| 57 | ||||
| 58 | ||||
| 59 | ||||
| 60 | Terminal 31 (Ground) | Terminal 31 | ||
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
- ↑ From Forum Reference: https://openinverter.org/forum/viewtopic.php?p=47620#p47620 VW Parts Store:https://parts.vw.com/p/Volkswagen__/Housing/64431217/5Q0906379.html (Backup: Web Archive)
