Mitsubishi Outlander AC Inverter
Revision as of 21:03, 22 May 2023 by ScottS (talk | contribs)
The Mitsubishi Outlander had an optional fitment of a 100/110/220V (Market dependent) ac outlet for the use of low power appliances.
This unit is labelled as part number 37129-01001
Warning - this information is not verified, just an observation at this stage! Ensure you make your own judgements regarding the connection of this unit!
Connection Label Mitsubishi Connector Number Comments
HV DC Connections + D-217-1 P
Ring Terminal connections labelled as + and -, appear to be designed to connect to ring terminal outlets from Power Distribution unit
HV DC Connections - D-217-1 N Ring Terminal connections labelled as + and -, appear to be designed to connect to ring terminal outlets from Power Distribution unit
AC outlet + D-216 AC1 Ring terminal connection labelled as + appears to be AC Outlet connection, cannot determine where Neutral/Negative connection is
AC outlet Not found Cannot identify the Negative connection for AC power
LV Connections 1 No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019
LV Connections 2 No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019
LV Connections 3 No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019
LV Connections 4 No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019
File:Mitsubishi Outlander AC Inverter 37129-01001 Main PCB Measurements.jpg
Main PCB with dimensions, HV DC connections top right, AC outlet bottom right, 4 pin LV connection middle left
File:Mitsubishi Outlander AC Inverter 37129-01001 Main Case.jpg
Non-sealed box, large rear heat sink, labelled as 37129-01001
File:Mitsubishi Outlander AC Inverter 37129-01001 Power Distribution Unit.jpg
Power Distribution Box for High Voltage, connects between REMCU, Heater unit and AC Inverter
File:Mitsubishi Outlander AC Inverter 37129-01001 HV Connections.jpg
High Voltage DC Input connections, and one other connection labelled +. Note - HVDC connections will only accept ring terminals to be connected
