Mitsubishi Outlander AC Inverter
The Mitsubishi Outlander had an optional fitment of a 100/110/220V (Market dependent) ac outlet for the use of low power appliances.
This unit is labelled as part number 37129-01001
Warning - this information is not verified, just an observation at this stage! Ensure you make your own judgements regarding the connection of this unit!
| Connection | Label | Mitsubishi Connector Number | Comments | ||
| HV DC Connections | + | D-217-1 P | Ring Terminal connections labelled as + and -, appear to be designed to connect to ring terminal outlets from Power Distribution unit | ||
| HV DC Connections | - | D-217-1 N | Ring Terminal connections labelled as + and -, appear to be designed to connect to ring terminal outlets from Power Distribution unit | ||
| AC outlet | + | D-216 AC1 | Ring terminal connection labelled as + appears to be AC Outlet connection, cannot determine where Neutral/Negative connection is | ||
| AC outlet | Not found | Cannot identify the Negative connection for AC power | |||
| LV Connections | 1 | No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019 | |||
| LV Connections | 2 | No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019 | |||
| LV Connections | 3 | No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019 | |||
| LV Connections | 4 | No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019 |
