Tesla Model S/X DC/DC Converter
Revision as of 18:04, 28 March 2023 by Asavage (talk | contribs) (Wiring: Re-org Wiring section for clarity; added some caption info to images.)
It is not to be confused with the earlier GEN1 DC-DC Converter, whose casing was of a kidney-shape, was located in the RF fenderwell against the firewall, and it incorporated functions of the front HVJB; it contains fuses for the coolant heater, cabin heater, and air-condition compressor, and servicing these fuses was never supported by Tesla (though is frequently performed in the aftermarket), so it developed a reputation for being unreliable due to frequent replacement for blown fuses. Though the hardware connections are different between GEN1 & GEN2, they both use the same (5) wired connections with the same functions, and the CAN commands appear to (may be) the same.
Tesla Model S GEN2 DC-DC Converter
Wiring
HV
Minimum required wiring for basic unit function: Five wires.
CAN lines are pins 2 & 3.
  • Orange (A/C): MG655773 (key A)
  • Gray (fluid heater): MG655774 (key B)
  • Brown (PTC heater): MG655775 (key C)
  • Blue (DC-DC): MG655776 (key D)
Donor Harness: Tesla OE/OEM Part Number: 1032804-00-A has two Blue DC-DC plugs.
Pinout for LV connector is written on the board
Pinout for LV connector is printed on the board.
LV & Signalling
LV connector (top row)
  • Pin 1 : HW-EN (Enable ("turn on") via applying 12v+ )
  • Pin 2 : CAN H
  • Pin 3 : CAN L
Control
CAN
CAN commands to request 14V at 500ms interval would be 0x2DD, but I need to provide additional +4 value to byte 1 because of enable bit value. Therefore 0x06 0xDD.
Msg is 3 byte long and value of data is swapped little endian so DD is byte0 and 06 is byte1
CAN ID 0x3D8 MSG DD 06 00
Reporting does not work if enable line is not high. Whenever i turn on enable i see reports.
Report is in telegram 0x210
0x210 8 bytes at 100ms
byte 2 = coolant inlet temp,
byte 3 = input power (16 W/bit),
byte 4 = output current (1 A/bit),
byte 5 = output voltage (0.1 V/bit)
Jason Hughes (wk057) posted this DC-DC Converter CAN information[1] in Jan2016:
Tesla Model S DC-DC Converter CAN information by Jason Hughes, (wk057), Jan2016.
The "CAN3" above refers to the specific CAN bus on the early Tesla Model S, which had (5) (later, (6)) CAN buses. CAN3 is the Powertrain CAN bus.
