Mercedes-Benz Chargers
With an increasing amount of Mercedes vehicles being electrified, there is a growing range of on-board chargers that can be repurposed for projects. At this stage, they are yet to be reverse engineered, but with a variety of versions available at reasonable cost, it is worth looking into.
Chargers
| Part Mumber | Version | Output | Voltage Range | Phases | Vehicles | Cooling | Notes |
| A0009001108 | AWL-1DC-3300W-LV | 3.3 kW | 170-360 | Single | S205
W205 |
Inlet on connector side | Manufactured by Delta |
| A0009004307 | AWL-1DC-3300W-HV | 3.3 kW | 240-440 | Single | W166
W222 X253 |
| A0009006420
A0009006520 |
OBC Gen 3.5 7.2 kW | 7.2 kW | 170-450 | Single (maybe Dual) | W167
W205 W213 E300e 2016-2024 X253 2015-2022 |
Inlet on connector side | Manufactured by Panasonic
Same 3 phase style AC input connector as some of the VW onboard chargers. May also support dual phase inputs. |
Data connectors are two 12 pin connectors, AC and DC connectors are yet to be identified.
Mercedes HV Charging harness cable is part number is A2055401604
