Lexus GS450h Drivetrain
Revision as of 03:00, 14 December 2022 by Mark (talk | contribs) (→Lexus GS450h VCU (deprecated): Collapsed deprecated section so as to visually take up as much of the page. The text can still be found via search and by expanding the section.)
  • Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
For technical analysis of this unit, see pages 14-47 of this document: [1]
Weight: 40 lbs
Buck/Boost Converter
Transmission
For technical analysis of this transmission, see pages 46 and onward of this document:[2]
It is a good idea to replace the two bearings in the electric oil pump before fitting a used transmission. There is a guide here[3]. Bearing part numbers are 61900-2Z and 608-2Z, you will need one of each.
GS450h shift position sensor
Oil Pump
Overview and location
Wiring and control
GS450h oil pump controller
Pinouts, schematics and notes
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
Connector Part No. Location
90980–12630
Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge.
Alternatives
Molex MX123 series
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064322-1039 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Assembly Instructions
Instructions on how to assemble the MX123 connector can be found here [4].
Transmission Connectors
ECT Solenoid (E83) Sumitomo 6189-1092 Located on the left hand side of the transmission above the oil pan.
Shift Lever Position Sensor (E80) Sumitomo 90980-12362 Located on the right side of the transmission next to the shift lever inhibitor switch.
MG1 & MG2 Resolver(s) (E81 & E82) Sumitomo 6189-1240 Two connectors located on the left side of the transmission by the bell housing.
Control Schemes
ZombieVerter VCU
