VAG MLBevo MQB Chargers
MEB Chargers
There are many different variants of MEB chargers with a wide range of potential power outputs.
Part Number | Version | Power Rating | Phase | Charger AC Inputs | Vehicle Usage | Coolant Connections | Comments | Reverse Engineered |
5QE915685 | 3.6kW | Single | One | |||||
5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | One | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | ||
5QE915682 | 3.6kW | Single | One | |||||
5QE915682AF | 3.6kW | Single | One | VW Golf MK7 Hybrid | Bottom | |||
5QE915682AG | 3.6kW | Single | One | Audi A3 8V e-tron | Bottom | |||
5QE915682AK | 3.6kW | Single | One | Yes | ||||
5QE915682M | 3.6kW | Single | One | VW Passat Hybrid | Bottom | |||
5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | One | VW e-Up!, SEAT Mii, SKODA e-Citigo iV | Left side | Made by Delta | |
5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | One | Porsche Cayenne Hybrid 2017-2021 | Left side | ||
5QE915681B | OBC 7200W | 7.2kW | Dual | One | VW e-Golf 2017-2022 | Bottom | Case not welded | |
5QE915681N | OBC 7200W | 7.2kW | Dual | One | VW e-Crafter | Bottom | Case not welded | |
5QE915684A | 11kW | Three | One | Audi e-tron | Opposite End of Electrical | |||
5QE915684AD | OBCTYPP110G10V01 | 11kW | Three | One | Audi e-tron | Opposite End of Electrical | ||
5QE915684BJ | OBCTYPP110G10V04 | 11kW | Three | One | Audi e-tron(?) | Right Side | ||
5QE915684J | OBCTYPP110G10V01 | 11kW | Three | One | Audi e-tron | Opposite End of Electrical | Replaces A and H variants | |
5QE915684BC | OBCTYPP110G10V05 | 11kW | Three | One | Porsche Taycan | Right Side | ||
5QE915684BK | OBCTYPP110G10V03 | 11kW | Three | Two | Porsche Taycan | Right Side | ||
9J1915681AD
9J1915681AH |
OBC 22kW C3 ROW | 22kW | Three | Two | Porsche Taycan | Right Side | longer case than other models | |
1EA915684BG | 11kW? | Three? | One | VW ID.3 MK1 | Bottom |
Pinouts
VW Golf PHEV | Seat Mii / VW e-Golf[2] | |||
Pin | Function | Comment | Function | Comment |
1 | Terminal 30 (permanent 12V) | Terminal 30 | ||
2 | ||||
3 | ||||
4 | Charge Port RGB LED +12v o/p | |||
5 | Charge Port RGB LED +12v o/p | |||
6 | ||||
7 | ||||
8 | ||||
9 | Powertrain CAN bus, high | Powertrain CAN bus, high | ||
10 | Powertrain CAN bus, low | Powertrain CAN bus, low | ||
11 | Hybrid CAN bus, high | Hybrid CAN bus, high | ||
12 | Hybrid CAN bus, low | Hybrid CAN bus, low | ||
13 | HVIL IN | HVIL IN | ||
14 | ||||
15 | HVIL OUT | HVIL OUT | ||
16 | Lock drive +. Drive to 12v to close lock. | |||
17 | Lock Drive – Drive to 12v to open lock | |||
18 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. | |||
19 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. | |||
20 | ||||
21 | Immediate charge buttons | |||
22 | Charge Port RGB LED +12v o/p | |||
23 | Control Pilot (CP) | |||
24 | Plug Present (PP) | |||
25 | Immediate charge buttons | |||
26 | ||||
27 | Temperature sender for charging socket. 1067R at approx 15C | |||
28 | Temperature sender for charging socket. 1067R at approx 15C | |||
29 | ||||
30 | ||||
31 | Charge port door lock actuator | |||
32 | Charge port door lock actuator | |||
33 | Charge port door lock actuator | |||
34 | Charge port door lock actuator | |||
35 | ||||
36 | ||||
37 | ||||
38 | ||||
39 | ||||
40 | ||||
41 | ||||
42 | ||||
43 | ||||
44 | ||||
45 | ||||
46 | ||||
47 | ||||
48 | ||||
49 | ||||
50 | ||||
51 | Immediate charge buttons | |||
52 | ||||
53 | ||||
54 | ||||
55 | ||||
56 | ||||
57 | ||||
58 | ||||
59 | ||||
60 | Terminal 31 (Ground) | Terminal 31 |
- ↑ From Forum Reference: https://openinverter.org/forum/viewtopic.php?p=47620#p47620 VW Parts Store:https://parts.vw.com/p/Volkswagen__/Housing/64431217/5Q0906379.html (Backup: Web Archive)
