Tesla Model S/X GEN2 Charger
tesla gen2 ac charger
The Tesla GEN2 charger is a single/three phase 10kW AC charger that was fitted in the Model S from 2012 until it was replaced in the 2016 'facelift' model with GEN3.
One or two GEN2 chargers are installed beneath the rear seats in the model s for ac charging.
The charger is made up of three 3.3 kw modules, each sitting on a liquid cooling plate. This assembly enables both single and multi phase ac charging.
Tesla Gen2 X-Ray
Replacement control boards
replacement control board https://github.com/damienmaguire/Tesla-Charger
Charger connection
The outputs will not output 12v, they are low side switches. If you require a 12v ac present signal then use a relay with its coil switched from the relevant pin.
Connector part numbers
  • housing: 044441-2006
Programming
you'll need a st-link v2 smt32 programmer. Unofficial ones are cheaply available from amazon and ebay.
Two options:
  2. Or commercial software: https://openinverter.org/files/stm32_charger.zip
External CAN bus
Gen2 Charger V5aB2 logic board with CAN wired to external pins
The V5aB2 version of the board has no connection to the external CAN bus (V5aB3 has) but you can add it with to bodge wires as shown in the picture. You will find CANH and CANL on the 3 pin header underneath the WiFi module. Route them over to CONN6 as shown. CONN2.1 (CANH) is connected to CONN6.24, CONN2.2 (CANL) to CONN6.26.
Revision V4aB3 does not need this modification. If you do NOT use the external CAN bus on that version remember to close the solder jumper next to R1 under the WiFi module.
If the charger is the first/last device on your CAN bus there is nothing else to do. If it is somewhere in the middle you have to remove the bus termination resistor R1.
Before doing this be aware that all internal CAN traffic is also seen on the external CAN bus. The following IDs are already used and mustn't used by any other device on the bus:
Charger CAN protocol - up to version 1.06.R
Charger CAN protocol - after version 1.06.R
Parameter view of commercial firmware
Commercial charger firmware
In addition to the open source firmware there is also a commercial firmware. It adds advanced features:
  • DC current control
Note: Its recommend that you change it. Nobody wants to drive and have some joker with a phone finding this information and accessing your charger.
Registration
The firmware will work without registration but charging time is limited to 5 minutes. To overcome this, a board-specific pin must be bought. In order to do this the firmware and web interface must be installed and working.
Go to the openinverter webshop and check out as many pins as you need. When checking out add the serial number(s) of your board(s) in the order option. You will find the serial number on the bottom of the page as last spot value.
You will then receive an email containing one pin for each board. Enter the pin in the web interface in the "pin" parameter. When the pin is correct it will be automatically saved to flash and your board is ready to be used.
Commercial firmware usage manual
We will go over all of them.
idclim
iaclim
idcspnt
chargerena
udcspnt
udclim
timelim
inputype
  • Type2: Specifies one or more modules are operated on ONE common phase of a Type-2 EVSE. The limits imposed by cablelim and evselim (pilot signal) are distributed equally over the enabled modules. For example if you enable all 3 modules, the cable allows 32A but the EVSE only allows 16A, every module will run at 16/3=5.3A. Charging will start automatically as soon as proximity and a valid pilot signal is detected.
  • Type2-3P: Specifies each module is connected to a different phase of a Type-2 EVSE. The limits imposed by cablelim and evselim are allowed for each module.
  • Type-2Auto: relies on input D2 to indicate that 3 phase is present (from external relay), to allow charging on either single or three phase automatically.
  • Type1: Like Type2 but cablelim is always assumed 40A.
  • Manual: Specifies one or more modules are operated on ONE common phase, power is distributed like in Type2 mode. Charging starts as soon as the enable pin "D1" goes high. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
  • Manual-3P: Specifies that each module is connected to a different phase of 3-phase outlet. Each module is allowed iaclim AC current. iaclim MUST be configured to the limits of your AC source as there is no automatic detection like in Type1 or Type2 modes.
cancontrol
idckp/idcki
pin
Additional Resources
The Tesla Project : 10 Kw Gen 2 Charger
The Tesla Project : Charger Progress
The Tesla Project : 10kW Charger Charging
The Tesla Project : More Charger Hacking
The Tesla Project : Charger 10kw Run
Common Issues
  • If you do NOT use the external CAN bus on that version remember to close the solder jumper next to R1 under the WiFi module.
