Toyota Prius Gen2 Inverter
- Note that there is also a [[Toyota_Prius_Gen3_Board for the 2010-2015 model years.
Replacement Controllers
| Pin # | Designation | Description | Wire Color
Wire Color
(Harness Side) |
| 1 | vacant | |||
| 2 | GIVA | MG1 Phase Current V | LightGreen | White - Cable 1 |
| 3 | GIVB | MG1 Phase Current V | Purple-Red | Black - Cable 1 |
| 4 | GUU | MG1 PWM U - Speed Signal Wave | Blue | Black - Cable 2 |
| 5 | GVU | MG1 PWM V - Speed Signal Wave | Blue-Red | Green - Cable 2 |
| 6 | GWU | MG1 PWM W - Speed Signal Wave | Yellow | Yellow - Cable 2 |
| 7 | MIVA | MG2 Phase Current V | LightGreen-Black | Green - Cable 3 |
| 8 | MIVB | MG2 Phase Current V | Purple-Yellow | White - Cable 3 |
| 9 | MUU | MG2 PWM U - Speed Signal Wave | Blue-Black | Black - Cable 4 |
| 10 | MVU | MG2 PWM V - Speed Signal Wave | Blue-Yellow | White - Cable 4 |
| 11 | MWU | MG2 PWM W - Speed Signal Wave | Yellow-Black | Red - Cable 4 |
| 12 | VH | Inverter Capacitor Voltage | Purple | Yellow - Cable 3 |
| 13 | CPWM | Boost converter PWM switch signal | Blue | Black - Cable 5 |
| 14 | CT | Boost converter temperature sensor | Green-Red | Red - Cable 5 |
| 15 | VL | Boost converter input voltage | Purple-White | Yellow - Cable 5 |
| 16 | GINV | Inverter Ground | Black-White | Yellow - Cable 4 |
| 17 | vacant | |||
| 18 | GIWA | MG1 Phase Current W | Grey | Red - Cable 1 |
| 19 | GIWB | MG1 Phase Current W | Grey-Black | Green - Cable 1 |
| 20 | GSDN | MG1 Shutdown | Brown-Black | Red - Cable 2 |
| 21 | GIVT | MG1 Inverter Temperature | Green-Black | White - Cable 2 |
| 22 | GFIV | MG1 Inverter Fail | White-Grey | Grey |
| 23 | MIWA | MG2 Phase Current W | Grey-Green | Red - Cable 3 |
| 24 | MIWB | MG2 Phase Current W | Grey-Red | Black - Cable 3 |
| 25 | MSDN | MG2 Shutdown | Brown | Green - Cable 3 |
| 26 | MIVT | MG2 Inverter Temperature | Green | Light Blue - Cable 4 |
| 27 | MFIV | MG2 Inverter Fail | White | Green |
| 28 | OVH | Overvoltage | Pink | Brown |
| 29 | CSDN | Boost converter shutdown signal | Brown-White | White - Cable 5 |
| 30 | FCV | Boost converter fail signal | White-Red | White |
| 31 | OVL | Boost converter over voltage signal | Pink-Blue | Black |
| 32 | GCNV | Boost converter ground | Black-Red | Green - Cable 5 |
(Article continues below)
DC-DC Converter
| Pin # | Designation | Description | Wire Color |
| 1 | IGCT | 12v+ | Blue |
| 2 | ID1 | Not Needed | Purple |
| 3 | S | B+ (opt) | White |
| 4 | NODD | 0-5v+ | Ppl/Gld |
| 5 | VLO | Not Needed | Blue |
| 6 | Vacant |
Inverter Cooling
Wiring
| Connector | Male | Female |
| C5 | 90980-10988 | 90980-10987 |
| B+ (DC-DC output) | 90980-11963 | |
| 32-pin connector | TE 1318747-1 (& 1123343-1 for pins) | |
| 28-pin connector (on inverter logic board) | TE 1565380-1 (& 1123343-1 for pins) |
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
- CSDN (pin 29 on inverter)
- Controls DC relay switch.
Physical setup
Process
Offgrid AC Use
