Schematics and connector pinout
joromy_tim_w_GND_fill_15b - Schematic.pdf
Name (New TIM) | Circuit (Old TIM) | Function (New TIM) | |
1 | NC | NC | |
2 | MTMP- | 3708 (BN) Motor Temp sensor | Motor Temp sensor Input - |
3 | DIS_DRV | 3404 (YE) Chg cord plugged in | Charge cable plugged in (12V, Motor PWM inhibit when low) |
4 | USART_TX | 3017 (DG/WH) SIADIS RXD | Serial comm. Or WiFi module |
5 | CAN_H | 914 (TN/OG) J1850 bus plus | CAN BUS |
6 | STOP_RLY | 3235 (YE/LG) Stop lamp RLY | Stop signal when regen (Active, GND. Inactive, Z) |
7 | VSS_OUT | 679 (GY/BK) Vehicle speed signal | Vehicle Speed Signal, to IAA and Power steering (12v PWM) |
8 | SIG_MAIN_C | 3986 (DG) Main contactor | DC contactor and oil pump relay (Active, GND. Inactive, Z) |
9 | 12V_ALL_T | 276 (BN) Power hot all time | 12V all time (used for relay protection diode) |
10 | 12V_RUN_START | 640 (RD/YE) Power run/start | 12v in RUN, START, ACC |
11 | MTMP+ | 3757 (BK/WH) Motor Temp sensor | Motor Temp sensor Input + |
12 | NC | NC | |
13 | 3.3V_USART | 3018 (WH) SIADIS d/l | Serial comm. Or WiFi module |
14 | USART_RX | 3016 (LG/BK) SIADIS TXD | Serial comm. Or WiFi module |
15 | CAN_L | 915 (PK/LB) J1850 bus minus | CAN BUS |
16 | NC | NC | |
17 | NC | NC | |
18 | PRECHG_RLY | 3991 (TN) Precharge RLY contr | Precharge relay (Active, GND. Inactive, Z) |
19 | 12V_ALL_T | 276 (BN) Power hot all time | 12V all time (used for relay protection diode) |
20 | 12V_RUN_START | 640 (RD/YE) Power run/start | 12v in RUN, START (this will power up the inverter ECU) |
21 | NC | NC | |
22 | NC | NC | |
23 | GND_USART | 3019 (GY/BK) SIADIS GND | Serial comm. Or WiFi module |
24 | NC | NC | |
25 | NC | NC | |
26 | SIG_VSS_B | 3701 (DB/WH) VSS B signal | Encoder channel B |
27 | NC | NC | |
28 | NC | NC | |
29 | GND | 3233 (BK/LB) GND | GND |
30 | 5V_VSS | 3707 (OG) VSS +12 ref | Encoder PWR +5V |
31 | CH_GND | 57 (BK) Chassis GND | Chassis GND |
32 | NC | NC | |
33 | NC | NC | |
34 | NC | NC | |
35 | EMCY_PWR | 3997 (DG) Emergency PWR Off | EPO Emergency Power Off (Active, Z. Inactive, 12V) |
36 | SIG_VSS_A | 3700 (LB/RD) VSS A signal | Encoder channel A |
37 | OIL_P_RLY | 3005 (VT/LG) Oil pump RLY | DC contactor and oil pump relay (Active, GND. Inactive, Z) |
38 | NC | NC | |
39 | GND | 3233 (BK/LB) GND | GND |
40 | GND_VSS | 3659 (BK/PK) VSS GND | Encoder GND |
