Toyota Prius Gen2 Inverter
Note: Wire colors on the male/female side of the 32-pin "i10" connector do not match. The inverter-side plug uses unique almost unique color scheme, but the wiring harness side reuses many colors - unique only to a given shielded cable (of which there are 5), plus some extra unbundled wires. To save time chasing wires, you can find anything in the same bundle, and know the rest by noting which other colors are in that cable. There are also a few loose wires not bundled into a cable or shielded.
| Pin # | Designation | Description | Wire Color
Wire Color
(Harness Side) |
| 1 | vacant | |||
| 2 | GIVA | MG1 Phase Current V | LightGreen | White - Cable 1 |
| 3 | GIVB | MG1 Phase Current V | Purple-Red | Black - Cable 1 |
| 4 | GUU | MG1 PWM U - Speed Signal Wave | Blue | Black - Cable 2 |
| 5 | GVU | MG1 PWM V - Speed Signal Wave | Blue-Red | Green - Cable 2 |
| 6 | GWU | MG1 PWM W - Speed Signal Wave | Yellow | Yellow - Cable 2 |
| 7 | MIVA | MG2 Phase Current V | LightGreen-Black | Green - Cable 3 |
| 8 | MIVB | MG2 Phase Current V | Purple-Yellow | White - Cable 3 |
| 9 | MUU | MG2 PWM U - Speed Signal Wave | Blue-Black | Black - Cable 4 |
| 10 | MVU | MG2 PWM V - Speed Signal Wave | Blue-Yellow | White - Cable 4 |
| 11 | MWU | MG2 PWM W - Speed Signal Wave | Yellow-Black | Red - Cable 4 |
| 12 | VH | Inverter Capacitor Voltage | Purple | Yellow - Cable 3 |
| 13 | CPWM | Boost converter PWM switch signal | Blue | Black - Cable 5 |
| 14 | CT | Boost converter temperature sensor | Green-Red | Red - Cable 5 |
| 15 | VL | Boost converter input voltage | Purple-White | Yellow - Cable 5 |
| 16 | GINV | Inverter Ground | Black-White | Yellow - Cable 4 |
| 17 | vacant | |||
| 18 | GIWA | MG1 Phase Current W | Grey | Red - Cable 1 |
| 19 | GIWB | MG1 Phase Current W | Grey-Black | Green - Cable 1 |
| 20 | GSDN | MG1 Shutdown | Brown-Black | Red - Cable 2 |
| 21 | GIVT | MG1 Inverter Temperature | Green-Black | White - Cable 2 |
| 22 | GFIV | MG1 Inverter Fail | White-Grey | Grey |
| 23 | MIWA | MG2 Phase Current W | Grey-Green | Red - Cable 3 |
| 24 | MIWB | MG2 Phase Current W | Grey-Red | Black - Cable 3 |
| 25 | MSDN | MG2 Shutdown | Brown | Green - Cable 3 |
| 26 | MIVT | MG2 Inverter Temperature | Green | Light Blue - Cable 4 |
| 27 | MFIV | MG2 Inverter Fail | White | Green |
| 28 | OVH | Overvoltage | Pink | Brown |
| 29 | CSDN | Boost converter shutdown signal | Brown-White | White - Cable 5 |
| 30 | FCV | Boost converter fail signal | White-Red | White |
| 31 | OVL | Boost converter over voltage signal | Pink-Blue | Black |
| 32 | GCNV | Boost converter ground | Black-Red | Green - Cable 5 |
DC-DC Converter
| Pin # | Designation | Description | Wire Color |
| 1 | IGCT | 12v+ | Blue |
| 2 | ID1 | Not Needed | Purple |
| 3 | S | B+ (opt) | White |
| 4 | NODD | 0-5v+ | Ppl/Gld |
| 5 | VLO | Not Needed | Blue |
| 6 | Vacant |
Inverter Cooling
Wiring
| Connector | Male | Female |
| C5 | 90980-10987 | 90980-10987 |
| B+ (DC-DC output) | 90980-11963 | |
| 32-pin connector | TE 1318747-1 (& 1123343-1 for pins) | |
| 28-pin connector (on inverter logic board) | TE 1565380-1 (& 1123343-1 for pins) |
Charging
Relevant Parameters
Charge mode:Buck
Chargecur: 1.5
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
Relevant Pins
- CSDN (pin 29 on inverter)
- Controls DC relay switch.
Physical setup
Process
