ZombieVerter VCU
- STM32-CAR project
- Openinverter
- ISA library
- Throttle cal and mapping,
- Temp derating,
- BMS limits,
- for/rev/neutral control,
- Graphing and monitoring,
- Cruise control,
- Fuel gauge driver,
- etc
So you've ordered your kit, first things first, watch the following video to assemble it.
Due to chip shortages (written summer 2021) the board isn't fully assembled so you will need to do some soldering, or take it to a local phone repair shop (or similar) who'll find soldering at this scale like playing with Duplo.
The enclosure kit links:
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads :
Note that in addition to the VCU, the inverter and transmission, you will require a specific canbus connected shunt: Isabellenhütte Heusler
Pin Out Diagram
Software
- Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
If it does not show up, check for errors and check that throtmax is not set to zero!
- Apply the Start 12V signal for a short time. The pre-charge relay should turn on, and the voltage available at the inverter and the udc input of the ISA shunt should quickly rise. If the udc reading goes above udcsw within 5 seconds then the main contactor(s) should close.
Supported OEM Hardware
- chevy volt HV water heater
- BMW E46 CAN support
- BMW E39 CAN support
- BMW E65 CAN Support
