Batteries
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
How quickly do you want to accelerate? Your motor's maximum power will be specified in kW. To estimate your maximum current draw, divide the peak power by the battery voltage. e.g. a 30 kW motor with a 120 V battery pack will pull 30,000 / 120 = 250 A. The higher the current rating of the cells, the heavier they will be for a given capacity. Ideally, you want "enough" current capacity for full throttle acceleration, but no more. You can put cells in parallel to double the current rating of your pack (which of course will half the voltage). Running cells in parallel is easy, but don't attempt to parallel battery packs unless you really know what you are doing. It's complicated.
Mass (kg)
Can your vehicle carry the weight? You'll need to keep the kerb weight within the original design limits. For a car, this could be a few hundred kg. For a motorcycle, likely less than 100 kg. This is a huge variable - and each new generation of battery tech seems to be a little lighter. For older EV or hybrid batteries, you can reckon on approximately 10 kg/kWh. Nissan Leaf batteries are relatively light (7.5 kg/kWh). With the latest technology (e.g. Kokam pouch cells or 18650s), you can get this down to 5-6 kg/kWh.
Volume (L)
Cell chemistry
LiFePO4 pouch cells
The majority of this content is drawn from this thread: https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761 discussing the use of the A123 20Ah pouch cell. However, many of the general points apply equally to other similar pouch cells.
General build requirements
Mylar, 'Fish paper' or a compliant foam may be appropriate materials to serve this purpose. This material should not be flammable. If the material is heat insulating, it is important to address thermal management.
Compression
*placeholder*
Taken directly from wb9k's post on endless sphere in the A123 thread
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Derived (barely paraphrased) from wb9k's post on endless sphere in the A123 thread
Increasing cell resistance may cause a number of symptoms which may be confused with High Self Discharge.
Lithium-ion
- Overcharging
Li-ion pouch cells
Kokam produce high-performance Li-ion pouch cells. These combine relative ease of use and pack construction with performance close to cylindrical cells.
OEM modules
| Manufacturer | Model | Capacity (kWh) | Weight (kg) | w (mm) | d (mm) | h (mm) | Gravity (kg/kWh) | Volume (L/kWh) | Voltage (V) | Current (cont A) | Current (peak A) | Cell arrangement | Cell type | Chemistry |
| Tesla | Model S 85kWh | 5.3 | 26 | 690 | 315 | 80 | 4.9 | 3.3 | 22.8 | 500 | 750 | 74p6s | 18650 | Li-ion |
| Tesla | Model S 100kWh | 6.4 | 28 | 680 | 315 | 80 | 4.4 | 2.7 | 22.8 | 870 | 86p6s | 18650 | Li-ion | |
| Tesla | Model 3 LR (inner) | 19.2 | 98.9 | 1854 | 292 | 90 | 5.2 | 2.5 | 91.1 | 971 | 46p25s | 2170 | Li-ion | |
| Tesla | Model 3 LR (outer) | 17.7 | 86.6 | 1715 | 292 | 90 | 4.9 | 2.5 | 83.9 | 971 | 46p23s | 2170 | Li-ion | |
| Tesla | Model 3 SR (inner) | 13.0 | 1854 | 292 | 90 | 3.7 | 91.1 | 603 | 31p25s | 2170 | Li-ion | |||
| Tesla | Model 3 SR (outer) | 12.0 | 1715 | 292 | 90 | 3.8 | 83.9 | 603 | 31p23s | 2170 | Li-ion | |||
| Calb | 4S3P | 2.19 | 12 | 355 | 151 | 108 | 5.5 | 2.6 | 14.6 | 900 | 3p4s | Pouch | Li-ion | |
| Calb | 6S2P | 2.19 | 12 | 355 | 151 | 108 | 5.5 | 2.6 | 22.2 | 600 | 2p6s | Pouch | Li-ion | |
| Chevrolet | Volt 2012 | 4 | 38 | 470 | 180 | 280 | 9.5 | 5.9 | 88.8 | 676 | 3p24s | Pouch | Li-ion | |
| BMW | i3 60Ah | 2 | 13 | 368 | 178 | 102 | 6.5 | 3.3 | 28.8 | 210 | 350 | 2p8s | Prismatic | Li-ion |
| BMW | i3 94Ah | 4.15 | 28 | 410 | 310 | 150 | 6.7 | 4.6 | 45.6 | 409 | 12s | Prismatic | Li-ion | |
| BMW | i3 120Ah | 5.3 | 28 | 410 | 310 | 150 | 5.3 | 3.6 | 45.6 | 360 | 12s | Prismatic | Li-ion | |
| Jaguar | iPace | 2.5 | 12 | 340 | 155 | 112 | 4.8 | 2.4 | 10.8 | 720 | 1200 | 4p3s | Pouch | Li-ion |
| LG | 4P3S | 2.6 | 12.8 | 357 | 151 | 110 | 4.9 | 2.3 | 11 | 4p3s | Pouch | Li-ion | ||
| Mitsubishi | Outlander | 2.4 | 26 | 646 | 184 | 130 | 10.8 | 6.4 | 60 | 240 | 16s | Li-ion | ||
| Nissan | Leaf 24kWh | 0.5 | 3.65 | 300 | 222 | 34 | 7.3 | 4.5 | 7.2 | 130 | 228 | 2p2s | Pouch | Li-ion LMO |
| Nissan | Leaf 30kWh | 1.25 | 300 | 222 | 34 | 3.6 | 14.4 | 2p4s | Pouch | Li-ion | ||||
| Nissan | Leaf 40kWh | 1.6 | 8.7 | 300 | 222 | 68 | 5.4 | 2.8 | 14.4 | 314 | 2p4s | Pouch | Li-ion NMC | |
| Nissan | Leaf 62kWh | 2.58 | 14.4 | 3p4s | Li-ion | |||||||||
| Volvo | XC90 T8 | 2.01 | 12.1 | 300 | 180 | 150 | 6.0 | 4.0 | 59.2 | 170 | 340 | 16s | Li-ion | |
| VW | Passet GTE | 23.4 | 24s | |||||||||||
| VW | Golf GTE |
