Batteries
Battery pack specification
Capacity (kWh)
How far do you want to go? A standard car conversion will need around 1kWh for 3 miles of range. For a middleweight motorcycle, 1kWh should give around 9 miles. Your mileage may vary, as they say.
Voltage (V)
Maximum current (A)
How quickly do you want to accelerate? Your motor's maximum power will be specified in kW. To estimate your maximum current draw, divide the peak power by the battery voltage. e.g. a 30 kW motor with a 120 V battery pack will pull 30,000 / 120 = 250 A. The higher the current rating of the cells, the heavier they will be for a given capacity. Ideally, you want "enough" current capacity for full throttle acceleration, but no more. You can put cells in parallel to double the current rating of your pack (which of course will half the voltage).
Mass (kg)
Can your vehicle carry the weight? You'll need to keep the kerb weight within the original design limits. For a car, this could be a few hundred kg. For a motorcycle, likely less than 100 kg. This is a huge variable - and each new generation of battery tech seems to be a little lighter. For older EV or hybrid batteries, you can reckon on 10-15 kg/kWh. Nissan Leaf batteries are relatively light (7.5 kg/kWh). With the latest technology (e.g. Kokam pouch cells or 18650s), you can get this down to 5-6 kg/kWh.
Volume (L)
Will it fit? Batteries are bulky. They are getting smaller, but finding enough space my be your biggest challenge. You can reckon on 5-10 L/kWh for older EV or hybrid batteries. For the latest technology (e.g. Kokam pouch cells or 18650s), you can get this down to 3-3.5 kg/kWh.
Cell chemistry
LiFePO4 pouch cells
The majority of this content is drawn from this thread: https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761 discussing the use of the A123 20Ah pouch cell. However, many of the general points apply equally to other similar pouch cells.
General build requirements
Mylar, 'Fish paper' or a compliant foam may be appropriate materials to serve this purpose. This material should not be flammable. If the material is heat insulating, it is important to address thermal management.
Compression
*placeholder*
Taken directly from wb9k's post on endless sphere in the A123 thread
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Derived (barely paraphrased) from wb9k's post on endless sphere in the A123 thread
Increasing cell resistance may cause a number of symptoms which may be confused with High Self Discharge.
Lithium-ion
- Overcharging
Li-ion pouch cells
Kokam produce high-performance Li-ion pouch cells. These combine relative ease of use and pack construction with performance close to cylindrical cells.
Cylindrical cells are favoured by Tesla, and are probably the main reason why their cars achieve such excellent performance. They are light, compact, powerful and expensive. Unfortunately, cylindrical cells are staggeringly difficult (and dangerous) to use in DIY conversions. There are two good reasons for this: thermal management and cell configuration.
As stated above, Li-ion cells are prone to thermal runaway. So you need perfect thermal management to ensure that no cell ever exceeds the critical temperature. If this happens, the cell will short-circuit internally, releasing a lot of energy - potentially explosively. Furthermore, the individual cells are small, so need to be arranged in parallel. In the case of the Tesla Model S, there are 74 cells in each parallel. Imagine if one of those cells fails and becomes short circuited internally. You now have 73 very high power cells in parallel feeding in to that short circuit. In fact, you don't have to imagine: you can watch this famous video instead (courtesy of Rich Rebuilds).
OEM modules
Using an OEM module means a lot of the difficulties associated with battery design are taken care of e.g. cooling, clamping, etc. Here is a list of OEM modules.
| Manufacturer | Type | Capacity (kWh) | Weight (kg) | w (mm) | d (mm) | h (mm) | Gravity (kg/kWh) | Volume (L/kWh) | Voltage (V) | Current (cont A) | Current (peak A) | Cell arrangement | Cell type | Chemistry |
| Tesla | Model S | 5.3 | 25 | 666 | 303 | 79 | 4.7 | 3.0 | 22.8 | 500 | 750 | 74p6s | 18650 | Li-ion |
| Chevrolet | Volt | 2 | 20.5 | 241 | 241 | 267 | 10.2 | 7.8 | 48 | 240 | 350 | 3p12s | Pouch | Li-ion |
