Batteries
Revision as of 19:13, 30 November 2020 by Clanger9 (talk | contribs) (Mass (kg))
Battery pack specification
Capacity (kWh)
How far do you want to go? A standard car conversion will need around 1kWh for 3 miles of range. For a middleweight motorcycle, 1kWh should give around 9 miles. Your mileage may vary, as they say.
Voltage (V)
How fast do you want to go? The pack voltage defines the maximum speed your motor can spin. Motors are usually specified with "KV" - or RPM-per-volt. Check the KV of your motor and how fast it needs to spin to get your desired top speed. e.g. if you need 3,000 RPM from a 25 KV motor then your pack voltage needs to be 3,000 / 25 = 120 V. The exact number of cells in series you need depends on the cell chemistry, but 3.8 V is a reasonable guess for Li-ion.
Maximum current (A)
How quickly do you want to accelerate? Your motor's maximum power will be specified in kW. To estimate your maximum current draw, divide the peak power by the battery voltage. e.g. a 30 kW motor with a 120 V battery pack will pull 30,000 / 120 = 250 A. The higher the current rating of the cells, the heavier they will be for a given capacity. Put cells in parallel to increase the current rating of your pack.
Mass (kg)
Can my vehicle carry the weight? You'll need to keep the kerb weight within the original design limits. For a car, this could be a few hundred kg. For a motorcycle, likely less than 100 kg. This is a huge variable - and each new generation of battery tech seems to be a little lighter. For older EV or hybrid batteries, you can reckon on 10-15 kg/kWh. Nissan Leaf batteries are relatively light (7.5 kq/kWh). With the latest technology (e.g. Kokam pouch cells or 18650s), you can get this down to 5-6 kg/kWh.
Volume (L)
Will it fit? Batteries are big. They are getting smaller, but finding enough space is often the biggest challenge. You can reckon on 5-10 L/kWh for older EV or hybrid batteries. For the latest technology (e.g. Kokam pouch cells or 18650s), you can get this down to 3-3.5 kg/kWh.
Lithium Iron Phosphate (LiFePO4) Batteries
Lithium Iron Phosphate (also known as LFP, or LiFePO4) batteries offer a good compromise between safety, energy density and ease of use for DIY conversions. They are available in a number of formats, commonly pouch cells and cylindrical cells.
LiFePO4 Pouch cells
The majority of this content is drawn from this thread: https://endless-sphere.com/forums/viewtopic.php?f=14&t=38761 discussing the use of the A123 20Ah pouch cell. However, many of the general points apply equally to other similar pouch cells.
General build requirements
Mylar, 'Fish paper' or a compliant foam may be appropriate materials to serve this purpose. This material should not be flammable. If the material is heat insulating, it is important to address thermal management.
Compression
Placeholder
Cylindrical cells
Placeholder
Situations likely to cause cell failure
Taken directly from wb9k's post on endless sphere in the A123 thread
Cell aging for LiIoPO4 cells
Derived (barely paraphrased) from wb9k's post on endless sphere in the A123 thread
Capacity loss is caused by the Lithium that was available for storage becoming permanently plated on the cathode. Being unable to move within the cell it is no longer available to store energy. The impact of this plating is greater than the amount of lithium 'lost' to plating because not only is the lithium no longer available, it is also preventing access to that part of the cathode meaning Li that can still move has to take a longer path to reach the cathode. Lithium plating is one cause of increased cell resistance (there are others), a sign of worsening cell health.
Increasing cell resistance may cause a number of symptoms which may be confused with High Self Discharge.
Lithium Ion Batteries
Lithium Ion (LiIon) batteries have a greater energy density than Lithium Iron Phosphate batteries, but have more challenging needs to use safely. The ideal operating range of LiIon batteries is between +15 and +45°C. The upper limit of temperature is particularly important as LiIon batteries experience thermal runaway - an unstoppable chain reaction that can occur in milliseconds releasing the stored energy in the cell. This can produce temperatures of 400°C and a fire that is extremely difficult to put out. Thermal runaway can start as low as 60°C and becomes much more likely at 100°C
  • Overcharging
LiIon Pouch cells
Placeholder
18650 and other cylindrical cells
Placeholder
