Toyota Prius Gen2 Board
- Large part availability, Prii have been made in large numbers for 20 years and spares are inexpensive.
- Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
Note: Colors below are for the internal wiring
| Pin # | Designation | Description | Wire Color
(Inverter Side) |
Wire Color
(Harness Side) |
| 1 | vacant | |||
| 2 | GIVA | MG1 Phase Current V | LightGreen | White |
| 3 | GIVB | MG1 Phase Current V | Purple-Red | Black |
| 4 | GUU | MG1 PWM U - Speed Signal Wave | Blue | Black |
| 5 | GVU | MG1 PWM V - Speed Signal Wave | Blue-Red | Green |
| 6 | GWU | MG1 PWM W - Speed Signal Wave | Yellow | Yellow |
| 7 | MIVA | MG2 Phase Current V | LIghtGreen-Black | Green |
| 8 | MIVB | MG2 Phase Current V | Purple-Yellow | White |
| 9 | MUU | MG2 PWM U - Speed Signal Wave | Blue-Black | Black |
| 10 | MVU | MG2 PWM V - Speed SIgnal Wave | Blue-Yellow | White |
| 11 | MWU | MG2 PWM W - Speed Signal Wave | Yellow-Black | Red |
| 12 | VH | Inverter Capacitor Voltage | Purple | Yellow |
| 13 | CPWM | Boost converter PWM switch signal | Blue | Black |
| 14 | GSDN | MG1 Shutdown | Green-Red | Red |
| 15 | VL | Boost converter input voltage | Purple-White | Yellow |
| 16 | GINV | Inverter Ground | Black-White | Yellow |
| 17 | vacant | |||
| 18 | GIWA | MG1 Phase Current W | Grey | Red |
| 19 | GIWB | MG1 Phase Current W | Grey-Black | Green |
| 20 | CT | Boost converter temperature sensor | Brown-Black | Red |
| 21 | GIVT | MG1 Inverter Temperature | Green-Black | White |
| 22 | GFIV | MG1 Inverter Fail | White-Grey | Grey |
| 23 | MIWA | MG2 Phase Current W | Grey-Green | Red |
| 24 | MIWB | MG2 Phase Current W | Grey-Red | Black |
| 25 | MSDN | MG2 Shutdown | Brown | Green |
| 26 | MIVT | MG2 Inverter Temperature | Green | Light Blue |
| 27 | MFIV | MG2 Inverter Fail | White | Green |
| 28 | OVH | Overvoltage | Pink | Brown |
| 29 | CSDN | Boost converter shutdown signal | Brown-White | White |
| 30 | FCV | Boost converter fail signal | White-REd | White |
| 31 | OVL | Boost converter over voltage signal | Pink-Blue | Black |
| 32 | GCNV | Boost converter ground | Black-Red | Green |
DC-DC Converter
| Pin # | Designation | Description | Wire Color |
| 1 | IGCT | 12v+ | Blue |
| 2 | ID1 | Not Needed | Purple |
| 3 | S | B+ (opt) | White |
| 4 | NODD | 0-5v+ | Ppl/Gld |
| 5 | VLO | Not Needed | Blue |
| 6 | Vacant |
Inverter Cooling
Through Hole Control Board
How To Use
Wire Connections
Control Board Pin mapping:
| TB1-1 | 12v-in | Primary 12v supply from ignition on |
| TB1-2 | GND | Primary ground connection to 12v negative. All grounds are common |
| TB1-3 | 5v VCC | 5V supply from board for use with throttle pot or hall pedal |
| TB1-4 | Throttle In | 0-5v variable voltage input from throttle pedal or pot |
| TB1-5 | Regen In | 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor |
| TB1-6 | GND | |
| TB1-7 | Brake In | 12v digital input from brake light switch. |
| TB1-8 | Start In | 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used. |
| TB1-9 | For In | 12v digital input commands motor to run in forward direction |
| TB1-10 | Rev In | 12v digital input commands motor to run in reverse direction |
| TB3-1 | +12v VCC | 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it). |
| TB3-2 | GND | Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it). |
| TB3-3 | Phase U |
| TB3-4 | Phase Y | Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive |
| TB3-5 | Phase W | Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive |
| TB3-6 | Current U | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-7 | Current Y | Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter. |
| TB3-8 | MG2 Enable | Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter |
| TB3-9 | MG2 Fault | Connect to MFIV for MG2 or GFIV for MG1 |
| TB3-10 | DC Bus | Connect to inverter VH to measure DC link voltage |
| TB2-1 | +5V VCC | 5v output to encoder for induction motor |
| TB2-2 | ENCA In | Encoder input A |
| TB2-3 | ENCB In | Encoder input B |
| TB2-4 | GND | Encoder ground |
| TB2-5 | HS Temp | Heatsink temp sensor input |
| TB2-6 | MOT Temp | Motor temp sensor input |
| TB4-1 | GND | Common ground |
| TB4-2 | Main Con | Main HV contactor control low side switch |
| TB4-3 | Precharge | HV precharge contactor control low side switch |
| TB4-4 | +12 V VCC | Spare 12v output |
| TB4-5 | CAN L | Can bus low signal |
| TB4-6 | CAN H | Can bus high signal |
New SMT control board with enclosure and designated pinouts
Please add pictures and description.
Pin Mapping - Note : Smaller 12-pin socket is the interface to the inverter & 20-pin to the motor
20 - Pin socket
Pin#01 - ENC_B/S3
Pin#02 - S1S4
Pin#03 - ENC_A/S2
Pin#04 - R1
Pin#05 - R2
Pin#06 - 5V
Pin#07 - THROTTLE 1
Pin#08 - THROTTLE 2
Pin#09 - START_IN (12V)
Pin#10 - BRAKE_IN (12V)
Pin#11 - FORWARD_IN (12V) (1, 2 or 3 way switch)
Pin#12 - REVERSE_IN (12V) (1, 2 or 3 way switch)
Pin#13 - Motor Temp -
Pin#14 - Motor Temp +
Pin#15 - DC (HV) Switch Control (Ground signal)
Pin#16 - Pre-ChARGE Control (Ground signal)
Pin#17 - CAN L
Pin#18 - CAN H
Pin#19 - Ground
Pin#20 - 12V "Ignition"
12 - Pin socket ( starts at pin number #21) - Corresponding pin on Main White 32 pin Inverter connector is in brackets.
Pin#21 - GIVA (2)
Pin#22 - MIVA (7)
Pin#23 - GIWA (18)
Pin#24 - MIWA (23)
Pin#25 - VH (12)
Pin#26 - MIVT (26)
Pin#27 - MFIV (27)
Pin#28 - MUU (9)
Pin#29 - MVU (10)
Pin#30 - MWU (11)
Pin#31 - CPWM (13)
Pin#32 - GINV/GCNV (16/32)
Connect MSDN Pin#25 in inverter (not 25 on controller) permanently to 12V to enable the MG2 Inverter (can be tied to same 12v source as "I9")
Connect CPWM to 12V via a 470 Ohm resistor for charge mode.
Connect the 2-pole white power connector ("I9") inside inverter to 12V and Ground to power up inverter electronics.
Initial Set up
Step 1 : Solder relevant (and included) connector pins to the Adapter Board
Step 2 : Plug in Wifi Adapter and connect ONLY Pin#19 - GROUND and Pin#20 - 12 Volts power supply
Confirm PWR LED lights up along with WIFI LED. Confirm ALIVE LED flashes.
Step 3 : Connect computer/laptop to the wifi network (Example - Inverter 7)
Step 4 : Go to browser toolbar and type in 192.168.4.1 + Enter. (allow pop ups/Trusted site). Confirm Web based Interface appears and list of parameters appear.
If parameters appear, you are now connected to the Adapter board and the Web based Interface - Congratulations - You are now in the Matrix !
Software
The Control Board runs Open Inverter software. A set of known-good default inverter parameters can be found here: https://openinverter.org/wiki/Configuration_Files#Toyota_Prius_Gen2_Inverter
Do NOT program a deadtime value for the Gen2 inverter. It only uses 1 PWM per phase and the inverter itself generates a low-side and high-side signal WITH deadtime.
