CAN bus with Arduino Due
Revision as of 02:30, 19 February 2023 by Asavage (talk | contribs) (Copied "Go to the GitHub webpage, and click on Code -> Download .ZIP" much earlier in the instructions.)
You will need the following:
  • An Arduino Due board
  • Two SN65HVD230-based CAN transceivers
  • An SPI Micro SD storage module (optional)
Here are the steps:
Configure your Arduino IDE
Download and install the Arduino IDE on your computer
Tools -> Board -> Boards Manager. Type "due" in the search box and install "Arduino SAM Boards (32-bits ARM Cortex-M3)"
Connect your computer to the "native" USB port on the Arduino Due board with a USB cable. The Due has two USB ports and they're used for different purposes. The port closer to the DC power connector is the "programming port" and the second is the "Native USB Port"
Make sure your Arduino board is selected with Tools -> Board: "Arduino Due (Native USB port)". Choose also the right port for the DUE from Tools -> Port.
File -> Examples -> 01.Basics -> Blink
Sketch -> Upload
Push the reset button on your Due. You should now see a blinking light. Congratulations! You've successfully compiled and loaded your first program and your IDE is working.
Get CAN transceivers working
This SN65HVD230 transceiver did not work
This SN65HVD230 transceiver worked
Due CAN loopback test
Tools -> Manage Libraries... Type "due_can" in the search box and install "due_can"
File -> Examples -> due_can -> CAN_ExtendedPingPong
Sketch -> Upload
Tools -> Serial Monitor
Install GV-RET
You need to install a number of libraries (in addition to the due_can library installed in the last section). These are all linked to on the GV-RET website, but a couple of them may not work properly if you install them via that method. I recommend you install the following via the Arduino IDE Library Manager with Tools -> Manage Libraries... :
  • SdFat
  • DueFlashStorage
Now install the remaining libraries manually. In each case, the installation procedure is:
  1. Download the .zip file: go to the GitHub webpage, and click on Code -> Download .ZIP
  2. Rename the file to remove "-master" or any other postfixes. This is important!
  3. Install the library with Sketch -> Include Library -> Add .ZIP Library... and select the file. Check that the names of the ZIP-files and the main folders in the ZIP-files are exactly as the packages listed below.
You need all of these:
Once the libraries are all installed, you can install GV-RET. Again, go to the GitHub webpage, and click on Code -> Download .ZIP.
Expand the .zip file and put the folder in your Arduino sketchbook location. Open the GV-RET project and install it as follows:
File -> Open -> GVRET.ino
Sketch -> Upload
If it doesn't compile and complains about missing libraries or headers, check the folder names in the Library folder. Remove any "-master" suffixes from the folder names. The folder names should match the library names listed above. If you installed wrong libraries (with a wrong name etc), delete them fist by deleting their folders from the arduino folder. For example with Windows users the folder can be C:\Users\Username\Documents\Arduino\libraries
Resetting to factory defaults
Using stored values for digital toggling system
Running on CANDue hardware
Build number: 343
Done with init
Add logging to SD card (optional)
You may have noticed the error message about the SD card. If you have an SPI SD card storage module, your Due will log CAN traffic to this for later analysis. This is ideal if you don't want to have to drive around with a laptop on the passenger seat...
The SD card module needs to be connected to the SPI header (in the middle of the Due board), plus one additional wire to data line 10.
Due SPI pins
Due SPI pins
Here are the connections:
SD module wiring
Pin on Due Pin on SD module
SPI MISO MISO
SPI SCK SCK
SPI VCC VCC
SPI MOSI MOSI
SPI GND GND
10 CS
The SD module can be a bit finicky. The GV-RET software defaults to running the SPI bus at 50MHz, but this didn't work for me. So you will need to do a bit of tweaking to fix this.
First of all, check your SD card is working with File -> Examples -> SdFat -> QuickStart. Connect your Due to the Programming USB Port (not the Native USB Port) and upload the program. In the serial console, it will ask for the CS pin. Enter '10'. You should see a little report in the serial console that shows it is working.
It may say you need to reformat your SD card. To do this, go to File -> Examples -> SdFat -> SdFormatter. Edit the source code to set the CS pin to 10 and limit SD clock speed to 4MHz:
const uint8_t chipSelect = 10;
#define SPI_SPEED SD_SCK_MHZ(4)
Upload the program and follow the instructions to format your SD card.
Now go to your GVRET code. Add this line after the line 'SdFat sd;' :
Find the line 'if (!sd.begin(SysSettings.SDCardSelPin, SPI_FULL_SPEED)) {' and change it to:
if (!sd.begin(SysSettings.SDCardSelPin, SPI_SPEED)) {
Due CAN bus logger with SD card storage
Find line SysSettings.SDCardSelPin = CANDUE_SDCARD_SEL; and edit to the pin number you are using.
SysSettings.SDCardSelPin = 10; // pin you are using
Find line settings.autoStartLogging = false; and change
settings.autoStartLogging = true;
That should be enough to get it working. Upload the sketch (this time using the Native USB Port) and you should be rewarded with:
Build number: 343
Done with init
At least the error message is gone. So far I haven't managed to get it to log anything to the SD card. It may be the GV-RET configuration needs to be tweaked...
Get started with SavvyCAN
SavvyCAN is a free, open source tool for analysing CAN traffic. Download and install it on your computer. It can be a bit intimidating, so here's a 30 minute tutorial to help you find your feet:
<youtube>kdA5Gdf3FAk</youtube>
If you're too impatient to sit through a tutorial, just dive straight in and connect to your Due. Go back to the Arduino IDE and note down the name of your Due's USB connection. On my Mac, it's "/dev/cu.usbmodem2441". You're now finished with the Arduino IDE, so quit it just in case it interferes with the next step...
In SavvyCAN:
Create New Connection
After a few seconds, you should see "Connected" in the Status field. If it doesn't connect, try pushing the reset button on your Due or click "Reset Selected Device" in SavvyCAN.
Now on to the fun part...
Start hacking
I will add something on my Ampera BMS (once I figure out an easy way to connect to the CAN bus...)
