External links
> CAN logs
LIM versions
SN | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | ||
61 35 9 494 498 | x | x | ? | BMW i3 | 2018? | x | |
61 35 9 470 199 | x | x | ? | BMW i3 | ? | ||
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
X | Replacement Pins | 5-962885-1 |
X | Rubber Seal | 1-967067-1 |
1B-1 | - | |
1B-2 | - | |
1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
1B-4 | LOCK_MOT+ | Charge Inlet Lock Motor |
1B-5 | LOCK_MOT- | Charge Inlet Lock Motor |
1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
1B-10 | GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | - | |
1B-14 | - | Internally connected to GND |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked) |
2B-1 | CP | Pilot (Charge Inlet) |
2B-2 | PP | Proxy (Charge Inlet) |
2B-3 | Jumper | Connected to Pin 4 |
2B-4 | Jumper | Connected to Pin 3 |
2B-5 | GND | Ground (Charge Inlet) |
2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
4B-2 | NEG_CONT+ | Negative HV Contactor Control |
4B-3 | POS_CONT- | Positive HV Contactor Control |
4B-4 | NEG_CONT- | Negative HV Contactor Control |
4B-5 | U_HV_DC | Charge Inlet DC Voltage (current input 3-20mA?) |
4B-6 | LED_RT | Red charge Status Light (12V RGB LED) |
4B-7 | LED_GN | Green charge Status Light (12V RGB LED) |
4B-8 | LED_BL | Blue charge Status Light (12V RGB LED) |
4B-9 | LED_GND | Charge Status Light Ground (common cathode of RGB LED) |
4B-10 | COV_MOT- | Charge Inlet Cover Motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Inlet Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Inlet Cover Feedback (connect to GND to simulate open cover) |
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
CAN communication
ID | Function | sent by | interval | Notes |
0x112 | BMS msg. | VCU or BMS | 10ms | could also be sent by BMS |
0x12F | Wake up | VCU | 100ms | needed |
0x3E9 | Main LIM control | VCU | 200ms | needed |
0x2F1 | Lim DC charge command 2. | VCU | 100ms | needed |
0x2FA | Lim DC charge command 3. | VCU | 1s | needed |
0x2FC | Charge flap control | VCU | 100ms | needed constant values |
0x431 | Battery info | VCU | 200ms | needed but does not control anything |
0x432 | BMS SoC | VCU or BMS | 200ms | display SoC needed |
0x03C | Vehicle status | VCU | 200ms | constant values |
0x1A1 | Vehicle speed | VCU | 20ms | constant values every 10ms works |
0x2A0 | Central locking | VCU | 200ms | constant values |
0x397 | OBD | VCU | 200ms | constant values |
0x3F9 | Engine info | VCU | 200ms | constant values. Rex only? |
0x3A0 | Vehicle condition | VCU | 200ms | constant values |
0x330 | Range info | VCU | 200ms | constant values |
0x51A | Network management | VCU | 200ms | constant values |
0x540 | Network management 2 | VCU | 200ms | constant values |
0x512 | Network management edme | VCU | 200ms | constant values |
0x560 | Network management kombi | VCU | 200ms | constant values |
0x510 | Network management zgw | VCU | 200ms | constant values |
0x328 | Counter | VCU | 1s | needed |
0x3E8 | OBD reset | VCU | 1s | constant values |
Messages sent by LIM | ||||
0x29E | CCS charger specs | LIM | ||
0x2EF | Min available voltage from the ccs charger. | LIM | ||
0x2B2 | Current and Votage as measured by the ccs charger | LIM | ||
0x3B4 | EVSE info CP, PP & inlet voltage | LIM | ||
0x272 | CCS contactor state and charge flap open/close status. | LIM | ||
0x337 | Inlet lock status | LIM |
LIM peripherals
Large fast charge contactor control
This makes it a bit harder to use different contactors.
The easiest option is to place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil and a small relais to drive the large Gigavac contactor with internal PWM economizer or dual coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Inlet lock feedback
The i3 uses a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
Charge control
The EVSE (charging station) shares it’s limits with PWM during IEC 61851/ J1772 AC charging or PLC during DIN 70121 or ISO 15118 CCS sessions but often the car can not handle the max available power of the charging station.
The actual battery voltage and battery current is needed by the LIM to check the respond of the charging station. In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard on the CAN bus by the BMS. (CAN message 0x112)
Battery dependant charging current control
During (fast) charging a cell voltage and cell temperature dependant current limit is very important.
CCS inlet temperature sensors
Many CCS inlets have DC contact temperature sensors to avoid overheating if the contact resistance is high for some reason. The LIM has no temperature sensor inputs but the VCU could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
On board charger control
The LIM shares measured PP (charging cable) and CP (charging station) AC current limits in the CAN message 0x3B4 EVSE info.
If the on board charger accepts a AC current limit this value can be directly used but some chargers can only be controlled with DC current commands.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage and charger efficiency.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
LIM logs
Observations
LIM board components
Chip | Description | Function | Datasheet |
Renesas V850E2/FG4 | 32-bit Single-Chip Microcontroller | main MCU | https://www.renesas.com/us/en/document/dst/data-sheet-v850e2fg4 |
Qualcomm QCA7000 | HomePlug® Green PHY, single chip solution | PLC Green PHY | https://openinverter.org/forum/download/file.php?id=9611 |
Infineon TLE 7263E | Integrated HS-CAN, LIN, LDO and HS Switch, System Basis Chip | CAN, 2xLDO, wake-up | https://docs.rs-online.com/db13/0900766b814d680b.pdf |
TI SN74LVC2T45-Q1 | Dual-Bit Dual Supply Transceiver with Configurable Voltage Translation | https://www.ti.com/lit/gpn/sn74lvc2t45-q1 | |
NXP 74LVC1T45 | Dual supply translating transceiver | https://datasheetspdf.com/pdf-file/648034/NXP/74LVC1T45/1 | |
STM L9951XP | Actuator driver | inlet lock motor | https://www.st.com/resource/en/datasheet/l9951.pdf |
STM TS321 | Low-Power Single Operational Amplifier | https://www.ti.com/lit/gpn/ts321 | |
TI LM2902 | Quadruple general-purpose operational amplifier | https://www.ti.com/lit/gpn/lm2902 | |
STM VNQ5E250AJ-E | Quad channel high-side driver with analog current sense | LEDs?, contactors? | https://www.st.com/resource/en/datasheet/vnq5e250aj-e.pdf |
