Lexus GS450h Drivetrain
Revision as of 14:30, 17 January 2021 by Jack Bauer (talk | contribs) (clean up)
The Lexus GS450h VCU is an open source project to repurpose 2006-2012 Lexus GS450h inverters for DIY EV use. It consists of a circuit board and programming that communicates with the original logic board in the inverter and allows independent control of it without communicating with a GS450h ECU.
Note that the Toyota Camry hybrid (US market) uses a similar inverter with the same logic board, which is functionally identical to the GS450h unit.
GS450h Inverter
Toyota Camry Inverter external connector
  • Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
The inverter is capable of running at full speeds on pack voltages from approx 280V upwards. The maximum allowable input voltage is 650V, so far, many have found that "standard" EV voltages of 300V-360V to be well suited.
Note that even thouigh the inverter maximum voltage rating is 650V, a 650V battery pack is not required to run this unit. It is capable of excellent performance at lower voltages, such as the typical 300V-360V found in most EVs. However, there is the opportunity to use larger packs with this unit if required in your application.
GS450h Converter
A buck/boost converter lives within the inverter housing, originally this is used to step up the 288V battery pack in the GS450h to the 650V for use in the inverter in the GS. (Note that this does not mean the inverter requires 650V to run, it is simply a maximum rating) For those using a 600+V battery pack, this converter can be used to step the voltage down to a more reasonable level to interface with charfgers, DCDC converters, heaters, AC compressors, and other components which can be found in "regular" EV's (Tesla, Leaf, Volt, etc).
GS450h Transmission
GS450h inverter
For technical analysis of this transmission, see pages 46 onwards of this document: https://www.osti.gov/servlets/purl/947393
The input shaft on the transmission has 21 splines, with a 28mm major diameter. It is believed that there are several Toyota clutches which will have this in their centre. The original GS450h flywheel and coupler also contains the appropriate slined centre, of course.
GS450h shift position sensor
  • It is recommended to purchase one which has the electric oil pump fitted - these are a costly item as the bearings in them often fail, in some cases they cost more than the transmission.
Transmission is tapered quite heavily, the width and height is closer to 25cm after the bellhousing, but hard to gauge due to various outcropping parts (motor cables, oil pump, PRNDL selector, etc)
The Oil Pump
<figure-inline><figure-inline><figure-inline><figure-inline></figure-inline></figure-inline></figure-inline></figure-inline> <figure-inline><figure-inline><figure-inline><figure-inline></figure-inline></figure-inline></figure-inline></figure-inline> <figure-inline><figure-inline><figure-inline><figure-inline></figure-inline></figure-inline></figure-inline></figure-inline> <figure-inline><figure-inline><figure-inline><figure-inline></figure-inline></figure-inline></figure-inline></figure-inline>
The metal case is the ground.
Black (pin 6) is PWM in from your controller.
Brown (pin 7) is feedback from the oil pump. It's PWM. Do what you want with this or leave it disconnected.
The fat blue wire (pin 5) is 12V power. The oil pump uses around 50A Max. So plan for that. Add your own relay to stop it draining your battery while the car is off.
The PWM for this is weird, it's not just 0-100. IIRC it is 0% at both ends, and rises to 100% near the middle, then back down again. This is just based on the sound of the pump with no load, so needs more testing to find the real values.
Here is a list of compatible Toyota part numbers for the oil pump controller: G1167-30020
Wiring Harness Connectors
Inverter Connectors
Connector Part No. Location
Inverter interface connector (A62) 90980–12630 Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge.
A good alternative to this, otherwise difficult to obtain, connector is to replace the receptacle/header with the following parts from Molex:
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064323-1029 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Transmission Connectors
ECT Solenoid (E83) Sumitomo 6189-1092 Located on the left hand side of the transmission above the oil pan.
Shift Lever Position Sensor (E80) Sumitomo 90980-12362 Located on the right side of the transmission next to the shift lever inhibitor switch.
MG1 & MG2 Resolver(s) (E81 & E82) Sumitomo 6189-1240 Two connectors located on the left side of the transmission by the bell housing.
HVECU -> Oil Pump Controller (A52) Single large (7-way) connector on the side of the oil pump controller
Control Board
An open-source VCU, designed by Damien Maguire, can be purchased as both partially populated and fully populated and tested boards on his website:
GS450h transmission and oil pump temperature sensor
Lexus GS450H VCM Fully Built and Tested
  • 33472-2002 (Left side, grey in colour)
  • 33472-2001 (Right side, black in colour)
  • 33012-2002 (Crimp terminals)
  • 5810130065 (Enclosure)
  • 5810140011 (Header, 40 Pos)
  • 75867-101LF (CONN1, Header for WiFi module)
  • 5787834-1 (CONN2, USB 2.0 receptacle)
  • TR10S05 (IC10, 5V DC/DC converter)
VCU Firmware
Firmware to run on the VCU is available on Github : https://github.com/damienmaguire/Lexus-GS450H-Inverter-Controller
Instruction for use :
Once connected, type ? and press enter. The following menu should then display :
  ?  - Print this menu
  D - Print configuration data
  f  - Calibrate minimum throttle.
  g  - Calibrate maximum throttle.
  i  - Set max drive torque (0-3500) e.g. typing i200 followed by enter sets max drive torque to 200
  q  - Set max reverse torque (0-3500) e.g. typing q200 followed by enter sets max reverse torque to 200
  v  - Set gearbox oil pump speed (0-100%) e.g. typing v50 followed by enter sets oil pump to 50% speed
  a  - Select LOW gear.
  s  - Select HIGH gear.
  z  - Save configuration data to EEPROM memory
? Will display the menu.
d Displays data from the inverter in this format :
   0    1    2    3    4    5    6    7    8    9
00 |                                            0    0
10 |    0    0              0    0    0    0    0    0
20 |    0    0    0    0    0    0    0    0    0    0
30 |    0              0    0    0    0              0
40 |    0    0              0    0    0    0    0    0
50 |    0    0    0    0    0
60 |
70 |
80 |    0    0              0    0              0    0
90 |    0    0    0    0    0    0    0    0
MTH Valid: Yes    Checksum: 0
DC Bus: ----v
MG1 - Speed: 0rpm    Position: 0
MG2 - Speed: 0rpm    Position: 0
Water Temp:    0.00c
Inductor Temp:    0.00c
Another Temp:    0c
Another Temp:    0c
D (capital or large D) displays VCU configuration data as well as information on the Gearbox status in this format :
Throttle Channel 1: 109
Throttle Channel 2: 53
Commanded Torque: 0
Selected Direction: DRIVE
Selected Gear: HIGH
Current valve positions:
PB1:ON
PB2:ON
PB3:ON
MG1 Stator temp: 109.69
MG2 Stator temp: 109.69
Throttle calibration procedure :
First, drive torque:
Configured drive torque: 500
Now torque:
Parameters stored to EEPROM
An option is provided to set the speed in % (0 to 100%) for the electric gearbox oilpump. In this example we set the speed to 50% :
I have found in testing on the E65 that 50% is a good value for keeping oil pressure up , providing cooling etc without running the pump too hard. Your millage may vary.
LOW Gear Selected
HIGH Gear Selected
Selecting Direction.
The firmware supports the use of the IN1 and IN2 pins of the V2 VCU as direction control inputs. Operation is as follows :
WiFi Display.
A wifi web browser based display is provided in order to easily visualise data from the inverter and gearbox.
Once powered, the wifi module will create an open access point with an ssid like ESP-XXXX where XXXX will be a series of letters and numbers.
Connect to this access point with any wifi enabled device (e.g. laptop, tablet, phone etc).
You may wish to change the ssid and add a passphrase to the access point. To do this goto : 192.168.4.1/admin
A simple set of dialog boxes will allow the ssid, passphrase and background colour of the gauge display to be set.
Development History
Vendors
There are currently no vendors who offer support on any aspects of the GS450h VCU.
Support
