CAN bus with Arduino Due
Revision as of 21:39, 9 November 2020 by Clanger9 (talk | contribs)
You will need the following:
  • An Arduino Due board
  • Two SN65HVD230-based CAN transceivers
  • An SPI Micro SD storage module (optional)
Here are the steps:
Configure your Arduino IDE
Download and install the Arduino IDE on your computer
Tools -> Board -> Boards Manager. Type "due" in the search box and install "Arduino SAM Boards (32-bits ARM Cortex-M3)"
Connect your computer to the the "native" USB port on the Arduino Due board with a USB cable. The Due has two USB ports and they're used for different purposes.
Make sure your Arduino board is selected with Tools -> Board: "Arduino Due (Native USB port)"
File -> Examples -> 01.Basics -> Blink
Sketch -> Upload
Push the reset button on your Due. You should now see a blinking light. Congratulations! You've successfully compiled and loaded your first program and your IDE is working.
Get CAN transceivers working
This SN65HVD230 transceiver did not work
This SN65HVD230 transceiver worked
Tools -> Manage Libraries... Type "due_can" in the search box and install "due_can"
File -> Examples -> due_can -> CAN_ExtendedPingPong
Sketch -> Upload
Tools -> Serial Monitor
Install GV-RET
You need to install a number of libraries (in addition to the due_can library installed in the last section).
Tools -> Manage Libraries... and install the following libraries:
  • SdFat
  • DueFlashStorage
Now install the following libraries manually. In each case, the installation procedure is:
  1. Download the .zip file
  2. Rename the file to remove "-master" or any other postfixes. This is important!
  3. Install the library with Sketch -> Include Library -> Add .ZIP Library... and select the file.
You need all of these:
Once the libraries are all installed, you can install GV-RET. Go to the GitHub webpage, and click on Code -> Download .ZIP.
Expand the .zip file and put the folder in your Arduino sketchbook location. Open the GV-RET project and install it
File -> Open -> GVRET.ino
Sketch -> Upload
Resetting to factory defaults
Using stored values for digital toggling system
Running on CANDue hardware
Build number: 343
Done with init
Get started with SavvyCAN
SavvyCAN is a powerful, free, open source tool for analysing CAN traffic. Download and install it on your computer. It can be a bit intimidating, so there's a 30 minute tutorial to help you find your feet:
<youtube>kdA5Gdf3FAk</youtube>
No doubt you're far to impatient to sit through a tutorial, so let's dive straight in and connect to your Due. Go back to the Arduino IDE and note down the name of your Due USB connection. On my Mac, it's "/dev/cu.usbmodem2441". You're finished with the Arduino IDE, so quit it just in case it interferes with the next step.
In SavvyCAN:
Create New Connection
After a few seconds, you should see "Connected" in the Status field. If it doesn't connect, try pushing the reset button on your Due or click "Reset Selected Device" in SavvyCAN. Now on to the fun part...
Start hacking
