Motor List
Overview of Motors
Detailed specs are available on the respective pages (click the link). If the manufacturer is clickable it should take you to the motor directly.
Manufacturer |
Model |
Technology |
Layout |
L¹[mm] |
W / ⌀²[mm] |
H[mm] |
Weight[kg] |
RWinding[mΩ] |
Cont. Power³[kW] |
Peak Power[kW] |
Power/Weight*[kW/ kg] |
Various |
100 |
80 |
1.82 |
32 |
130-180 |
2 |
7 |
1.10 |
Various |
100 |
80 |
1.4 |
130-180 |
6 |
104 |
98 |
2.7 |
57 |
2 |
5 |
0.74 |
78 |
96 |
2 |
78 |
2.5 |
5 |
1.25 |
110 |
98 |
3 |
49 |
3 |
6 |
1.00 |
105 |
126 |
4.3 |
45 |
5 |
10 |
1.16 |
68 |
134 |
2.7 |
40 |
2.5 |
6 |
0.93 |
126 |
127 |
4.8 |
43 |
6 |
15 |
1.25 |
100 |
165 |
5 |
45 |
8 |
15 |
1.60 |
122 |
165 |
8 |
45 |
12 |
20 |
1.50 |
51 |
81 |
0.964 |
30 |
275 |
2 |
3 |
2.07 |
86 |
81 |
1.814 |
50 |
137 |
4 |
6 |
2.21 |
150 |
100 |
7.851 |
50 |
35 |
100 |
105 |
2.360 |
150 |
23 |
120 |
120 |
3.935 |
150 |
23 |
148 |
201 |
212 |
9.98 |
13 |
104? |
3.84 |
10.56 |
0.39 |
182 |
200 |
247 |
15.88 |
13 |
52? |
12 |
30 |
0.76 |
182 |
200 |
247 |
15.88 |
65 |
69? |
10 |
24 |
0.62 |
163 |
201 |
253 |
15.88 |
65 |
69? |
10 |
24 |
0.62 |
182 |
201 |
253 |
15.88 |
130 |
52? |
12 |
30 |
0.76 |
203 |
9.98 |
13 |
4.47 |
14.17 |
0.45 |
203 |
10.14 |
25 |
4.47 |
14.17 |
0.44 |
16.47 |
10 |
24 |
0.61 |
171 |
223 |
252 |
15.88 |
13 |
52? |
12? |
30? |
0.76 |
203 |
9.98 |
4.47 |
11.19 |
0.45 |
153 |
220 |
250 |
19.96 |
17 |
0.85 |
150 |
201 |
212 |
9.98 |
12 |
4.32 |
14.4 |
0.43 |
111 |
201 |
13 |
2.4 |
110 |
201 |
4.8 |
2.4 |
110 |
201 |
212 |
25 |
5 |
13 |
150 |
201 |
212 |
9.98 |
25 |
4.32 |
0.43 |
15.88 |
65 |
68? |
12 |
30 |
0.76 |
167 |
223 |
260 |
15.88 |
130 |
54? |
15 |
38 |
0.94 |
190 |
254 |
10 |
10 |
30 |
260 |
254 |
10 |
20 |
50 |
190 |
254 |
7 |
10 |
30 |
260 |
254 |
7 |
20 |
50 |
160 |
15.42 |
16 |
18 |
7 |
23 |
0.45 |
140 |
11 |
9.3 |
5 |
0.45 |
MXUS |
142 |
9.34 |
8.9 |
3 |
6 |
0.32 |
140 |
247 |
8.98 |
8.8 |
2 |
5 |
0.22 |
140 |
244 |
8.3 |
0.5 |
0.06 |
QS Motor |
150 |
247 |
12.75 |
9 |
3 |
0.24 |
150 |
317 |
18.1 |
11 |
4 |
0.22 |
100 |
232 |
6.16 |
100 |
12.5 |
0.5 |
1 |
0.08 |
135 |
230 |
6.28 |
82 |
13.9 |
0.5 |
1 |
0.08 |
135 |
239 |
6.5 |
6.5 |
0.25 |
2 |
0.04 |
105 |
232 |
7.37 |
123 |
10.4 |
0.6 |
1.2 |
0.08 |
105 |
232 |
7.73 |
84 |
13 |
0.6 |
1.2 |
0.08 |
173 |
3.94 |
55 |
8.1 |
0.5 |
1 |
0.13 |
100 |
173 |
2.68 |
96 |
12.7 |
0.25 |
0.5 |
0.09 |
100 |
131 |
2.4 |
0.25 |
0.5 |
0.10 |
92 |
300 |
330 |
24 |
50 |
165 |
2.08 |
107 |
305 |
330? |
27 |
60 |
160 |
2.22 |
125 |
273 |
260 |
15 |
19 |
145 |
271 |
260 |
20 |
45.5 |
145 |
271 |
260 |
20 |
50 |
85 |
207 |
9.1 |
0.8 |
58 |
20 |
80 |
2.20 |
85 |
207 |
9.4 |
0.8 |
58 |
20 |
80 |
2.13 |
85 |
207 |
9.3 |
0.8 |
58 |
25 |
80 |
2.69 |
86 |
228 |
12 |
1.12 |
40 |
28 |
100 |
2.33 |
86 |
228 |
12.3 |
1.12 |
40 |
28 |
100 |
2.28 |
86 |
228 |
12.3 |
1.12 |
40 |
35 |
100 |
2.85 |
91 |
268 |
19.9 |
1.7 |
22.2 |
40 |
160 |
2.01 |
91 |
268 |
20.3 |
1.7 |
22.2 |
40 |
160 |
1.97 |
91 |
268 |
20.3 |
1.7 |
22.2 |
50 |
160 |
2.46 |
91 |
268 |
20.3 |
11.5 |
8.2 |
50 |
200 |
2.46 |
254 |
178 |
16 |
25 |
41 |
1.56 |
95 |
308 |
317 |
20 |
90 |
155 |
4.5 |
77 |
308 |
317 |
12 |
45 |
75 |
3.75 |
115 |
398 |
429 |
38 |
90 |
200 |
2.37 |
224 |
398 |
429 |
78 |
180 |
400 |
2.31 |
256 |
292 |
328 |
51.5 |
70 |
120 |
1.36 |
174 |
292 |
328 |
26 |
28 |
51 |
1.08 |
256 |
292 |
328 |
51 |
93 |
156 |
1.82 |
344 |
292 |
328 |
76 |
145 |
220 |
1.91 |
280 |
359 |
383 |
52 |
90 |
125 |
1.73 |
¹ without shaft, minimum required dropout width on (bicycle) hubs
² if cylindrical
³ actual S1 or S2 (60 min) rating, in italic text if estimate not supplied by manufacturer, details in specsheet
* based on continuous rating
Technology
BLDC - any waveform
WC = water cooling
OC = oil cooling
H = built in Hall sensors
S = built in sin/cos encoder
Layout
Hub, optionally geared (⚙⚙) and/or B for bicycle (if designed to have a sprocket mounted)
Inrunner, optionally AG for Axial Gap ("Pancake Style", AKA as Axial Flux)
Note: this page is discussed on Motor selection: sortable table in the Wiki
Use Motor Specsheet Template to copy and paste from when you create a detailed Specsheet from a red link
