CAD Models
Revision as of 22:58, 18 March 2026 by Maboyce (talk | contribs) (Moved iPace scan to right section)
This section has been added to allow people to post external links to existing CAD models that are freely available and are broken up by subcategory. Many models are already available, however if you can't find an existing model, there is a section at the end labelled Requests where members can login and simply add a line to this section with a short description of the component they would like.
Please note: all models should include an external link with an acknowledgement to the host and original creator.
Batteries
Manufacturer Model Host Site Author/Creator Link
LG Chem 4p3s Module Zero EV Chris Hazell https://zero-ev.co.uk/cad/
CALB 3p4s Module Zero EV Chris Hazell https://zero-ev.co.uk/cad/
Nissan Leaf Gen 1 Cell GrabCAD Brock Winberg https://grabcad.com/
Nissan Leaf 24 kWh pack GrabCAD Kevin Kuehn https://grabcad.com/
Tesla Model S/X 5.3kWh Battery Module Openinverter Forum https://openinverter.org/forum/
Tesla Model 3 Passenger side inboard battery module Openinverter Forum https://openinverter.org/forum/
Tesla Model 3 Passenger side outboard battery module Openinverter Forum https://openinverter.org/forum/
Tesla Model 3 Driver side inboard battery module Openinverter Forum https://openinverter.org/forum/
Tesla Model 3 Driver side outboard battery module Openinverter Forum https://openinverter.org/forum/
Tesla Full Model S Battery Pack GrabCAD saurabh dhuri https://grabcad.com/
Mitsubishi Outlander Yuasa 8 cell module GrabCAD https://grabcad.com/
VW GTE Golf/Pasaat 2x12s module with plate GrabCAD TomdB https://grabcad.com/
Stellantis Peugeot E-208/Corsa E 50kWh module GrabCAD Manny https://grabcad.com/
Hyundai Hyundai Ioniq 5 / Kia EV6 2P6S module GrabCAD Rick Mellor https://grabcad.com/
VAG Porsche Taycan / Audi e-Tron GT module GrabCAD Alex https://grabcad.com/
LG Chem Chrysler Pacifica 16s module GrabCAD DIY ElectricCar https://grabcad.com/
VW ID3/4 module GrabCAD Paul Baque https://grabcad.com/
Inverters
Nissan Leaf Gen 2 Drive Unit GrabCAD Paul Baque https://grabcad.com/
Nissan Leaf Gen 2 (EM57) GrabCAD James Harris https://grabcad.com
Nissan Leaf Gen 1 Inverter GrabCAD coming soon
Toyota Yaris (Gen 3) Inverter GrabCAD coming soon
Toyota Prius (Gen 3) Inverter GrabCAD https://grabcad.com/
Toyota Prius (Gen 3) Inverter Openinverter Forum Anders https://openinverter.org/forum/
Toyota Prius (Gen 2) Inverter GrabCAD coming soon
Lexus GS-450H Inverter phone scan GrabCAD https://grabcad.com/
Lexus GS-450H Inverter scan GrabCAD TomdB https://grabcad.com/
Lexus IS-300H Inverter GrabCAD TomdB https://grabcad.com/l
Mitsubishi Outlander Rear GrabCAD TomdB https://grabcad.com/
Motors
Lexus GS-450H GrabCAD coming soon
Nissan Leaf Gen 1 (EM61) with gearbox GrabCAD coming soon
Nissan Leaf Gen 2 (EM57) GrabCAD Julius Wächter https://grabcad.com
Toyota Prius Gen 3 Transaxle GrabCAD coming soon
Toyota Prius Gen 2 Transaxle GrabCAD coming soon
Toyota MGR GrabCAD TomdB https://grabcad.com/
Lexus GS450h Gearbox GrabCAD TomdB https://grabcad.com/
Drive Units (motor/gearbox/inverter)
Nissan Leaf Gen 2 (EM57) GrabCAD James Harris https://grabcad.com/library/nissan-leaf-em57-motor-inverter-pdu-gearbox-1
Tesla Model S/X SFDU GrabCAD Brock Winberg https://grabcad.com/library/tesla-front-small-drive-unit-3d-scan-1
Tesla Model S/X SRDU GrabCAD James Warner https://grabcad.com/library/tesla-rear-small-drive-unit-3d-scan-1
Tesla Model S/X LDU GrabCAD Winston Jennings https://grabcad.com/library/tesla-rear-drive-unit-1
Tesla Model S/X LDU with subframe GrabCAD joe k https://grabcad.com/library/tesla-model-s-large-drive-unit-1
Tesla Model 3/Y RDU GrabCAD Zero EV https://zero-ev.co.uk/cad/
Tesla Model 3/Y RDU with subrframe GrabCAD Matt Brown https://grabcad.com/library/tesla-model-3-rear-subframe-and-motor-1
Misubushi PHEV Rear Drive Unit GrabCAD Volt Influx https://grabcad.com/library/outlander-phev-rear-motor-1 and https://grabcad.com/library/outlander-phev-rear-gearbox-1
MG ZS 2017-2020 Front unit GrabCAD LRBen https://grabcad.com/library/2017-2020-mg-zs-front-drive-unit-1
Jaguar iPace Front GrabCAD Jamie Jones https://grabcad.com/
Chargers
Mitsubishi Outlander GrabCAD TomdB https://grabcad.com/
Nissan Leaf Gen 1 GrabCAD coming soon
Tesla Model S Gen 2 Openinverter Forum https://openinverter.org/forum/
Tesla PCS GrabCAD Wim Boone https://grabcad.com/
Gearboxes
Nissan Leaf GrabCAD James Harris https://grabcad.com
HV Components
AC Compressor Nissan GrabCAD James Harris https://grabcad.com
Mitsubishi Outlander Water Heater GrabCAD TomdB https://grabcad.com/
Mitsubishi Outlander AC Compressor GrabCAD TomdB https://grabcad.com/
VW Egolf/GTE Heater GrabCAD TomdB https://grabcad.com/
VW Egolf/GTE AC Compressor GrabCAD TomdB https://grabcad.com/
VW IDx Air PTC GrabCAD TomdB https://grabcad.com/
Miscellaneous
Type Manufacturer Model Host Site Author/Creator Link
Current Shunt Tesla P85 GrabCAD https://grabcad.com/library/1430339
Current Shunt ISA IVT-S 500 GrabCAD TomdB https://grabcad.com/
Current Shunt ISA IVT-S 1K GrabCAD TomdB https://grabcad.com/
Coolant Valve Tesla Model S/X 3way Valve GrabCAD TomdB https://grabcad.com/
Coolant Pump BMW 5 Series Pierburg GrabCAD TomdB https://grabcad.com/
Power steer pump TRW From Opel Astra GrabCAD J0hannes Link
BMW i3 LIM BMW I3 GrabCAD Wim Boone https://grabcad.com/
HV DC Contactor Tesla Model 3/Y GrabCAD Wim Boone https://grabcad.com/
CCS Contactor Tesla Model 3/Y GrabCAD Wim Boone https://grabcad.com/
12V Penthouse connector Tesla Model 3/Y GrabCAD Wim Boone https://grabcad.com/
Accelerator Pedal Cable Sensor Honda Element GrabCAD Matt Boyce https://grabcad.com/
Empty battery tray Tesla Model 3 GrabCAD Kaleb Reinhart https://grabcad.com
BMS Orion 24 - 180 cell models Orion Orion https://www.orionbms.com/
Requests
Please add your requests here for any CAD models or scans that you have been unable to find online or in the tables above. See example below:
Example request: Motor - Nissan - Leaf Gen 1 EM61 (without gearbox)
Motor - Lexus - GS300H
Engine compartment - BMW - E9x
Battery pack - BMW - PHEV
Note: If anyone is able to take a scan or source an existing model for a request, please add it to the tables above and remove the request from this section. Many thanks.
