Tesla Model 3 Drive Unit PCB Parameters
Revision as of 18:18, 13 December 2025 by Davefiddes (talk | contribs) (Parameter Reference: More sensible limits for oil temp)
The [stm32-sine M3_DU] firmware has additional parameters over the regular stm32-sine Parameters.
Parameter Reference
The following additional parameters can be configured:
Motor
encmode 0 6 0 6=High frequency 8.8kHz resolver exciter to support the Tesla M3 resolver
snsm 12 24 12 Motor temperature sensor. 24=TeslaM3. Note: Some drive units are not fitted with a sensor but this should still be selected to ensure correct operation of the inverter firmware.
snshs 0 8 0 Heatsink temperature sensor. 12=TeslaM3
Oil Pump
tmpoilmax °C 70 100 100 Maximum permitted temperature for the oil. As the oil temperature gets within 10°C of the maximum the throttle will be limited to be 10% per °C. For example at 9°C below the limit the throttle cannot exceed 90%.
tmpoilhigh °C 10 100 45 The upper temperature bound for the oil speed control. If the temperature exceeds this the pump will operate at full speed (255).
tmpoillow °C 10 100 25 The lower temperature bound for the oil speed control. If the temperature exceeds this the pump speed will vary linearly between pumpspeed or pumpspeedidle and the maximum possible speed.
pumpspeed dig 0 255 70 The minimum speed (0-255) of the oil pump when the inverter is in run mode. The speed can be higher at elevated temperatures.
pumpspeedidle dig 0 255 17 The minimum speed (0-255) of the oil pump when the inverter is idle. The speed can be higher at elevated temperatures to pull heat out of the motor after the vehicle has come to a stop.
Spot Values
The following additional values are available for diagnostic purposes:
Name Unit Description
tmpoil °C The oil temperature as measured by the oil pump in the drive unit. This can be used as a proxy for the motor temperatures for drive units which lack a dedicated sensor.
upmp V Supply voltage to the oil pump (typically 12-14V)
pmprev RPM The rotational speed of the oil pump in rpm.
oilpres PSI The oil pressure measured by the pump
m3_phaseA_hi The status of the Phase A high-side gate driver chip on the inverter PCB. Anything other than "Ok" indicates a serious fault.
m3_phaseA_lo The status of the Phase A low-side gate driver chip on the inverter PCB.
m3_phaseB_hi The status of the Phase B high-side gate driver chip on the inverter PCB.
m3_phaseB_lo The status of the Phase B low-side gate driver chip on the inverter PCB.
m3_phaseC_hi The status of the Phase C high-side gate driver chip on the inverter PCB.
m3_phaseC_lo The status of the Phase C low-side gate driver chip on the inverter PCB.
