'Raven' Model 3 based Front Drive Unit
** Unusable until OpenInverter Support for Model 3 based Drive Units are released**
The Model S/X currently offers the 'Raven' Drivetrain...
Base difference with this drivetrain is the addition of a new Front Drive Unit. This new front drive unit is, at it's core, a repackaged M3 Performance Drive Unit.
The Repackaging means that it generally will fit in similar cases where the older Front SDU will fit.
Quick Facts:
- Permanent Magnet Rotor
- Uses Model 3 based inverter, confirmed same PCB # as other M3 based units
- At least one unit confirmed to be shipped with the 24 SiCFET inverter (800A '980' inverter)
- Similar Shared design with the Plaid Front Drive Unit.
- Raven Part#: 1478000-01
- Plaid Part#: 1478100-01 (Reference: E-Bay - Seller reference from Disassembled Plaid DriveTrain)
Specs:
- Input Voltage : 280 – 404VDC
- Input curent Peak : 800A
- Power peak : 250 kw
- Rotor speed : 18,000 rpm max
- Torque peak : 444Nm 327 ft/lb
- Regen : 65kw
(Taken from 980 rear drive unit specs)
3D Scan Data:
- Underway, Link to be posted to GrabCad
Part Numbers:
- Full Assembly:
- Motor #: 1478000-01
- Inverter:
- Housing: P1117428-00-C
- Casing: 1085693-00-F
- PCB: 1078289
- Part#: 186592-13-H
