The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new, it comes without firmware loaded, and it must be programmed first.
External links
> CAN logs
Connectors and Pinouts
| 1B | 16 Pin Connector | (?Hirschmann 805-587-545?)[2]Auto-Click UK Part link has Pin 13 through 16 blocked. Received a Mercedes Part from them instead of BMW using this part number. Please check the part for proper compatibility |
Audi 7M0 973 119 |
| 1B-2 | - | |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | |
| 2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! | Pilot (charge port) |
3B Pinout:
- N/A (for CHAdeMO only)
Wiring Diagram
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[12] from the high voltage DC voltage.
Fast charge contactor
Larger contactor control
Charge port
Make sure to match these if you want to use a different charge port. Some brands use different resistance values.
Charge port lock
- Connector shell: BMW 12527549033[13] or Hirschmann 805122541[14]
- Terminals: BMW 61131393724
RGB charge indication light
Wake/sleep
- On plug insertion.
Programming a new LIM
If you purchase a new LIM, there is no configuration loaded; it is "virgin", and must be configured before use.
There are at least two ways to program a virgin BMW i3 LIM:
- Use BMW E-Sys software in combination with a salvaged Body Domain Controller, and possibly requiring a matching physical key[15];
- Use a Vector CAN (or similar) and a Fahrzeugauftrag (FA) file to edit and write information to the LIM without E-Sys[16]
Programming LIM using E-Sys and a BDC/Key
Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
- Software:
- Hardware:
- Car key from the same car as the BDC. EDIT: this may not be necessary as the BDC can be put into "on" mode by running the full fault delete function using ISTA [17]
Programming LIM using Vector CAN and Fahrzeugauftrag (FA) file
- Hardware requirement: TBD
- Software requirement: BMW E-sys v3.34 (tested[18])
- Advantages/Disadvantages
Charge control
Contactor Test
- Fault set in 0x272 byte 2
CCS inlet temperature sensors
CAN communication
| Messages sent by LIM | ||||
LIM logs
Observations
LIM hardware
Physical dimensions
LIM versions
| Part No. | IEC 61851
J1772 (AC) |
| 61 35 6 828 052 | BMW i3 | Aug 2019[19] | |||||
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Charging protocols
Signaling circuit
AC charging
CCS DC charging
