VCU Comparison
Revision as of 04:44, 18 January 2023 by Celeron55 (talk | contribs)
Draft by celeron55
VCU Comparison TODO:
- Add outlander vcu - Add johu's vcu - Fill in missing info - Add links
VCU Comparison:
- Open source software
   - ipdm: Yes
   - zombie: Yes
   - GEVCU7: Yes
- Open source hardware
   - ipdm: No
   - zombie: Yes
   - GEVCU7: No
- Schematics and board layouts available:
   - ipdm: Yes
   - zombie: Yes
   - GEVCU7: No
- Price (roughly inc. VAT + shipping + enclosure):
   - ipdm: 135€
   - zombie: 350€
   - gevcu7: 1500€
- In stock:
   - ipdm: 2023-02
   - zombie: Yes
   - gevcu7: Yes
- External connector pins:
   - ipdm, zombie: 56
- External connector pin size range, A:
   - ipdm, zombie: 5A?
- Primary use case
   * ipdm: Power distribution, I/O extension
   * zombie: Inverter control including Toyota
   * GEVCU: CAN inverter control, logging
- Software platform:
   - ipdm: Arduino
   - zombie: libopeninv
   - GEVCU7: Arduino
- External configuration interface:
   - ipdm: USB serial, TTL serial
   - zombie: Wifi
   - gevcu7: Bluetooth, Wifi, USB serial
- Configuration format:
   - ipdm: Arduino sketch
   - zombie: Parameter list
- Out-of-the box supported inverter brands:
   - ipdm: None
   - zombie: OpenInverter, Nissan, Toyota, Lexus, Outlander?
   - gevcu7: DMOC, CODA, Brusa, PM100, C300
- MCU family:
   - ipdm: AVR
   - zombie: STM32F1
   - gevcu7: iMXRT1062
- Flash
   - ipdm: 32kB
   - gevcu7: 16MB
- RAM:
   - ipdm: 2kB
   - gevcu7: 1024kB
- Supply voltage range:
   - ipdm: 8...16V
- Standby mode description:
   - ipdm: 6mA running Arduino sketch at slow clock speed
- Buses:
   - ipdm: 2x CAN
   - zombie: 3x CAN, 1x Toyota, 1x LIN, 1x RS232?
   - gevcu7: 3x CAN
- Number of inputs:
   - ipdm: 14
   - zombie: 10?
   - gecvu7: 12
- Analog inputs (including throttle and external NTC channels):
   - ipdm: 5
   - zombie: 6?
   - gevcu7: 8
- PWM inputs:
   - ipdm: 2
- Additional special inputs:
   - ipdm: 12V battery voltage monitoring
- Signal PWM outputs:
   - ipdm: 0
   - zombie: 1?
- Power PWM outputs (low / high side, A):
   - ipdm: 4x L 3A
   - zombie: 3x L ?A
- Low-side power outputs, total A / count:
   - ipdm: 20A / 10x
   - zombie: 5A (limited by ground pin) / 9x?
   - gevcu7: 16A / 8x
- High-side power outputs, total A / count
   - ipdm: 15A / 10x
- Analog outputs:
   - ipdm: 2x 0-500mA low side slow
   - zombie: 2x AC coupled, 2x digital resistors
- Power outputs readable as inputs:
   - ipdm: 8
- Simultaneous customizable jumpers/resistors:
   - ipdm: 32
   - zombie: 0?
