External links
> CAN logs
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
X | Replacement Pins | 5-962885-1 |
X | Rubber Seal | 1-967067-1 |
X | (for the connector on the i3's Charge Port Cable Lock, |
1B-1 | LED_S | Charge Port Lighting (not necessary) |
1B-2 | ZV_LKL+ | Charge Port door lock motor (+) (not necessary) |
1B-3 | LED_M | Charge Port Lighting (not necessary) |
1B-4 | LOCK_MOT+ | Charge Port cable Lock Motor |
1B-5 | LOCK_MOT- | Charge Port cable Lock Motor |
1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
1B-10 | GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | SENS_LKL | Charge Port door Lock sensor
(must be tied to ground for contactors weld test[1]) |
1B-14 | ZV_LKL- | Charge Port door Lock motor (-) (not necessary); Internally connected to GND |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
1B-16 | LOCK_FB | Charge Port cable Lock Feedback (1k unlocked, 11k locked) |
2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! |
2B-2 | PP | Proximity (charge port) |
2B-3 | Jumper | Connected to Pin 4 |
2B-4 | Jumper | Connected to Pin 3 |
2B-5 | GND | Ground (charge port) |
2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
4B-2 | NEG_CONT+ | Negative HV Contactor Control |
4B-3 | POS_CONT- | Positive HV Contactor Control |
4B-4 | NEG_CONT- | Negative HV Contactor Control |
4B-5 | U_HV_DC | Charge port DC Voltage (current input 3-20mA?) |
4B-6 | LED_RT | Red charge Status Light (12V RGB LED) |
4B-7 | LED_GN | Green charge Status Light (12V RGB LED) |
4B-8 | LED_BL | Blue charge Status Light (12V RGB LED) |
4B-9 | LED_GND | Charge Status Light Ground (common cathode of RGB LED) |
4B-10 | COV_MOT- | Charge Port Cover motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Port Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Port Cover Feedback (connect to GND to simulate open cover) |
Wiring Diagram
Note [18Jun2022 ALS]: In the above diagram, some details may be non-current, eg the Charge Port door sensor is not shown, but its line @ 1B-13 must be tied to ground (ie the "door" must be open) for the LIM to proceed with charging.
Wiring notes
Fast charge contactor
Larger contactor control
Charge port
Charge port lock
- Connector shell: BMW 12527549033 (ref. jon volk)
- Terminals: BMW 61131393724
RGB charge indication light
Charge control
CCS inlet temperature sensors
CAN communication
ID | Function | sent by | interval | Notes |
0x112 | BMS msg. | VCU or BMS | 10ms | could also be sent by BMS |
0x12F | Wake up | VCU | 100ms | needed |
0x3E9 | Main LIM control | VCU | 200ms | needed |
0x2F1 | Lim DC charge command 2. | VCU | 100ms | needed |
0x2FA | Lim DC charge command 3. | VCU | 80ms...1s | needed (low interval during CCS start up) |
0x2FC | Charge flap control | VCU | 100ms | needed (constant values work) |
0x431 | Battery info | VCU | 200ms | needed but does not control anything |
0x432 | BMS SoC | VCU or BMS | 200ms | display SoC needed |
0x03C | Vehicle status | VCU | 200ms | (constant values) needed? |
0x1A1 | Vehicle speed | VCU | 20ms | (constant values) 10ms works needed? |
0x2A0 | Central locking | VCU | 200ms | (constant values) needed? |
0x397 | OBD | VCU | 200ms | (constant values) needed? |
0x3F9 | Engine info | VCU | 200ms | (constant values) needed? |
0x3A0 | Vehicle condition | VCU | 200ms | (constant values) needed? |
0x330 | Range info | VCU | 200ms | (constant values) needed? |
0x51A | Network management | VCU | 200ms | (constant values) needed? |
0x540 | Network management 2 | VCU | 200ms | (constant values) needed? |
0x512 | Network management edme | VCU | 200ms | (constant values) needed? |
0x560 | Network management kombi | VCU | 200ms | (constant values) needed? |
0x510 | Network management zgw | VCU | 200ms | (constant values) needed? |
0x328 | Counter | VCU | 1s | needed |
0x3E8 | OBD reset | VCU | 1s | (constant values) needed? |
Messages sent by LIM | ||||
0x29E | CCS charger specs | LIM | ||
0x2EF | Min. available voltage from the CCS charger. | LIM | ||
0x2B2 | Current and Voltage as measured by the CCS charger | LIM | ||
0x3B4 | EVSE info: CP, PP & inlet voltage | LIM | ||
0x272 | CCS contactor state and charge flap open/close status. | LIM | ||
0x337 | Inlet lock status | LIM |
LIM logs
Observations
LIM hardware
LIM versions
SN | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | ||
61 35 6 828 052 | BMW i3 | Aug 2016 | |||||
61 35 9 494 498 | x | x | ? | BMW i3 | 2018? | x | |
61 35 9 470 199 | x | x | ? | BMW i3 | ? | ||
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Chip | Description | Function | Datasheet |
Renesas V850E2/FG4 | 32-bit Single-Chip Microcontroller | main MCU | https://www.renesas.com/us/en/document/dst/data-sheet-v850e2fg4 |
Qualcomm QCA7000 | HomePlug® Green PHY, single chip solution | PLC Green PHY | https://openinverter.org/forum/download/file.php?id=9611 |
Infineon TLE 7263E | Integrated HS-CAN, LIN, LDO and HS Switch, System Basis Chip | CAN, 2xLDO, wake-up | https://docs.rs-online.com/db13/0900766b814d680b.pdf |
TI SN74LVC2T45-Q1 | Dual-Bit Dual Supply Transceiver with Configurable Voltage Translation | https://www.ti.com/lit/gpn/sn74lvc2t45-q1 | |
NXP 74LVC1T45 | Dual supply translating transceiver | https://datasheetspdf.com/pdf-file/648034/NXP/74LVC1T45/1 | |
STM L9951XP | Actuator driver | inlet lock motor | https://www.st.com/resource/en/datasheet/l9951.pdf |
STM TS321 | Low-Power Single Operational Amplifier | https://www.ti.com/lit/gpn/ts321 | |
TI LM2902 | Quadruple general-purpose operational amplifier | https://www.ti.com/lit/gpn/lm2902 | |
STM VNQ5E250AJ-E | Quad channel high-side driver with analog current sense | LEDs?, contactors? | https://www.st.com/resource/en/datasheet/vnq5e250aj-e.pdf |
Charging protocols
Signaling circuit
AC charging
CCS DC charging
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications, but since most of the protocols used are similar it has comparable sequence diagrams, with descriptions for normal start up, normal shutdown, DC supply-initiated emergency stop and EV-initiated emergency stop.
