As these can be found affordably on eBay and from auto wreckers, they have been pursued as an open-source charger project.
CAN logs and other data
https://github.com/damienmaguire/BMW-i3-CCS
Power Limits
The limits for pre 2017/26 are 0V-500V 0A-250A, post 2017/27 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
| 1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
| X | Replacement Pins | 5-962885-1 |
| X | Rubber Seal | 1-967067-1 |
| 1B-1 | LED_S | Lighting Charge Socket |
| 1B-2 | ZV_LKL+ | Charge Door Lock Motor |
| 1B-3 | LED_M | Lighting Charge Socket |
| 1B-4 | ZV_LADE+ | Hood Lock |
| 1B-5 | ZV_LADE- | Hood Lock |
| 1B-6 | CAN | |
| 1B-7 | CAN | |
| 1B-8 | Wake up signal | |
| 1B-9 | Power | |
| 1B-10 | Ground | |
| 1B-11 | ||
| 1B-12 | ||
| 1B-13 | SENS_LKL | Charge Door Lock Sensor |
| 1B-14 | ZV_LKL- | Charge Door Lock Sensor |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enabled signal for the in car charger? |
| 1B-16 | ZV_LADE | Hood Lock |
| 2B-1 | Pilot | |
| 2B-2 | Proxy | |
| 2B-3 | Diag? Looped back to Pin 4? | |
| 2B-4 | ||
| 2B-5 | GND | Ground. (Charge Socket) |
| 2B-6 |
3B Pinout:
- N/A
| 4B-1 | HV+_SZ+ | Contactor Control |
| 4B-2 | HV-_SZ+ | Contactor Control |
| 4B-3 | HV+_SZ- | Contactor Control |
| 4B-4 | HV-_SZ- | Contactor Control |
| 4B-5 | U_HV_DC | |
| 4B-6 | LED_RT | Charge Status Light |
| 4B-7 | LED_GN | Charge Status Light |
| 4B-8 | LED_BL | Charge Status Light |
| 4B-9 | BR_GND | Charge Status Light |
| 4B-10 | ZV_LS- | Charge Socket Locking |
| 4B-11 | ZV_LS+ | Charge Socket Locking |
| 4B-12 | SENS_LS | Charge Socket Locking |
