Prius Gen 3 Inverter Boost Inductor Electrical Aspects
Posted: Fri Aug 28, 2020 3:01 am
by johnspark
I am interested in the Boost Inductor, so have started a thread just to capture some of this data that may be useful to someone,
kind regards Johnspark
Re: Prius Gen 3 Inverter Boost Inductor Electrical Aspects
Posted: Fri Aug 28, 2020 3:04 am
by johnspark
I have measured the inductance of this inductor to be using a DE-5000: 258.5uH @ 10kHz.
Measured the DC resistance using a DC current source to be: 0.141V / 8.77A = 0.016 ohms.
Posted: Mon Aug 31, 2020 7:32 am
by wwojciech
Mayby we can use this boost inductor with this project
https://www.diyelectriccar.com/threads/ ... ger.36627/
Posted: Mon Aug 31, 2020 9:09 am
No, this was the barebones charger and it had a nasty habit of measuring battery voltage in between pauses. This caused lights flicker in house and other wierd sounds...
The charger that i lean to is EMW design, which is a derivative of upper one, but it has good serial control and isolated measurements. I run it for 7 years now in 3phase with very good results. Read up on the thread. Firmware is sort of open source....DOH!
https://www.diyelectriccar.com/threads/ ... ign.59210/
Posted: Wed Sep 02, 2020 4:21 am
by Bratitude
any one have a part number?
