Page 9 of 10
Re: Nissan Leaf Gen3 inverter
Posted: Fri Mar 25, 2022 2:59 am
by Z600EV
Kelju, Any updates on if you got your adapter board working in the Gen 3 inverter?
Posted: Mon Mar 28, 2022 9:50 am
by JamesWLG
Jestroman wrote: Thu Mar 10, 2022 10:40 am i was going to use those solderless joiners that you heat?
Those types of joiners are ok for use in military aircraft so go ahead just use a good heat gun with the wrap around attachment thingy to heat all round at once, and make sure the solder flows.
Posted: Tue Mar 29, 2022 9:31 pm
by Alibro
JamesWLG wrote: Mon Mar 28, 2022 9:50 am
A little inconclusive but pretty much sums up what I said earlier.
Posted: Wed Mar 30, 2022 5:19 pm
by Doig5710
As a auto sparky who works on normal cars and builds race looms as well, please don't use these heat solder joiners, there rubbish, either crimp join it with the dual wall heatshrink or solder it with a soldering iron and heatshrink, these things will fail in the future making your life not very fun trying to find the cause of a dodgy signal somewhere.
Posted: Mon Apr 25, 2022 4:10 pm
by Dala
OlegAzeo wrote: Sat Nov 13, 2021 7:17 pm my 160kw inverter installed on leaf 2014 gives max 145kw and 400A, why is that? changed the multiplier and there is no difference at the maximum current.
I too am struggling with the 400A limit with a 40kWh pack. I've seen screenshots from Leafspy Pro with 180kW (500A), so something is missing to get it to output more.
I tried to modify the available battery power ( LB_Discharge_Power_Limit ) message in 0x1DC ti 180kW, just like the 62kWh pack sends it, but it did not help.
Anyone here got any ideas?
Posted: Wed May 04, 2022 12:43 pm
by Dala
I have concluded that we won't get further with raising power from 400A -> 500A without a native LEAF 2019 e+ EV-CAN log.
Anyone got one? :D
Posted: Thu Jun 02, 2022 7:03 pm
by Dala
I got the logs! From an e+. Still no luck with getting 500A, but we are getting there slowly. I got a lot of fault codes cleared now that I know what to send on the bus.
Before code:
After code:
I think that the reason we don't get 500A is due to having fault codes active. If I were writing automotive code, I would put the vehicle in some limp mode when fault codes are active. Let's see if we can get rid of that last U1000!
Posted: Thu Jun 02, 2022 8:00 pm
by eCRX
Go Dala Go! 👍👍
100%. Would be like asking for full power on an ICE with a major sensor fault. An ECM just won't allow it.
Posted: Thu Jun 02, 2022 8:32 pm
by Dala
Thanks @eCRX , now I made some more progress, just two more codes to squash!
I will update the inverter code on github once I get the last two ones fixes. The P318E in particular sounds quite bad; "Traction motor inverter is unable to receive the EV system CAN signal from VCM"
Either of the following statuses is observed.
• No impact to vehicle behavior
• Stops drive control of traction motor
So getting that one cleared is now top prio!
Posted: Sat Jun 04, 2022 9:37 am
by Dala
I finally got it 8-)
Now the code sends enough CAN messages to make the system believe everything is fine:
I've updated the inverter code on Github: https://github.com/dalathegreat/Nissan- ... inverter.c
Warning, that code is r o u g h. I will optimize it later on when I know that it actually gives 500A now.
Now to continue with some error-free roadtesting....
Posted: Sat Jun 04, 2022 12:36 pm
by Alibro
You're wasted on the likes of us mate.
What a star, well done. :)
Posted: Tue Jul 12, 2022 12:32 am
by Letins
thank you!
Posted: Sat Jul 30, 2022 4:43 pm
by SciroccoEV
Do we know what the battery voltage limit is on the OEM Nissan logic board?
Also, from what I've been able to glean on-line, the 160kW inverter has a higher rpm limit and therefore top speed, than the 110kW. Can anyone confirm that this is the case and it's not different gearing.
Posted: Sat Aug 13, 2022 6:38 am
by Letins
There is no gear, everything is hidden by the power plate inforce drivers above it. a logic board provides communication and monitoring through it with the ev control module, if the open inverter bard used is not needed
Posted: Tue Aug 23, 2022 11:25 pm
by eCRX
Any updates? Any possibility of a gen3 brain board this year? :geek:
Posted: Thu Aug 25, 2022 9:26 pm
Possible but unlikely
viewtopic.php?t=2324
Posted: Mon Sep 19, 2022 7:52 pm
by Zapatero
I received two inverters, one 160Kw and one 110Kw
I opened both Inverters, one is 5WK0A which is 110 Kw
the other one is 5SN0A which is 160Kw and one 110Kw
As stated before they are the same except for the main board!
Posted: Wed Sep 21, 2022 6:54 am
by Zapatero
I ordered this Plug and tried to plug it in on the inverter - it does not fit!
Are there any alternatives?
Posted: Wed Sep 21, 2022 7:35 am
by Alibro
Zapatero wrote: Wed Sep 21, 2022 6:54 am I ordered this Plug and tried to plug it in on the inverter - it does not fit!
You could approach Dave at South West EV (on Youtube). I know he cooked his old inverter and bought another so might have a spare connector or Dala.
I noticed before the HV battery connector is different to the inverter connector even though they look the same.
Posted: Wed Sep 21, 2022 9:36 am
by pilt
Zapatero wrote: Mon Sep 19, 2022 7:52 pm I received two inverters, one 160Kw and one 110Kw
Do you think the flash could be coppied from the 160kW inverter into the 110kW? :)
Posted: Wed Sep 21, 2022 2:48 pm
by Bratitude
dam it! dose part of the assembly fit? is it the key way or are the pin location different ?
Posted: Wed Sep 21, 2022 6:53 pm
by Zapatero
Except for the outer ring the amount of pins and the distance between them is totally different!
Posted: Thu Sep 22, 2022 1:47 pm
by janosch
Zapatero wrote: Wed Sep 21, 2022 6:53 pm ...
We might have a spare one here that we can post to you, I would need to "check inventory".
Edit: Apologies, we left it on the donor cars when taking the HV towers out.
Edit Edit: Look who it is!
Posted: Wed Oct 26, 2022 9:10 pm
by vin
Hi All,
So I've managed to drag my 2019 110Kw stack into the house to work on it, and got the wiring connected, however I can't seem to get much response out of it, I monitoring CAN and get IDs 0x1DA 0x120 and 0x55A for about 5 seconds then nothing. I've tried supplying power to the inverter separately from the PDM, with and with HV (207VDC Prius Pack) and nothing. Any ideas anyone?
Much appreciated.
Posted: Fri Nov 04, 2022 8:30 pm
by Dala
vin wrote: Wed Oct 26, 2022 9:10 pm I monitoring CAN and get IDs 0x1DA 0x120 and 0x55A for about 5 seconds then nothing. I've tried supplying power to the inverter separately from the PDM, with and with HV (207VDC Prius Pack) and nothing. Any ideas anyone?
You need to start sending 0x11A 0x1D4 and 0x50B towards the inverter right away, otherwise it goes to sleep. http://productions.8dromeda.net/c55-lea ... tocol.html
